Lurker
Unanswered: Fuse block replacement
As for "off-the-shelf", you can use probably most anything you imagination and enginuity will allow. Ron did a circuit breaker (ala military) type on "Willit". There's pics of it in his blog.
You can find 8 or 10 circuit fuse blocks that you make up to your own needs in most of the hot rod catalogs ....Summit Racing ..Etc. HTH
John
![]() Provided Answers: 10
Kwik Wire ~ Add On Fuse Blocks I hope this answers your question.
We do it in a very simple way which has proven itself over the years. You will need a good up to date electrical schematic for the vehicle and start by labeling each conductor that reaches a post on the old fuse block. We then disconect and remove the old fuse box, clean the area and mount the new fuse box in place. The new unit has individual terminals which are labeled so matching the old and the new connections should be very simple and straight forward. The problem comes when you end up with several conductors which used to go to the steering and dash assemblies connectors. This is the time consumming part, you will need to identify the individual conductors and find a new connecting point for each one. Take your time, double check each connection until they are all done. I have been wanting to re-work the original Opel Electrical schematics with a fuse panel like this one. Time has always been the problem.
What about one of the kits from painless?
Painless Performance: The Official Home Page For The Best In Automotive and Diesel Performance Products My only worries would be with the dash wiring. |
We have used them both with good results, to us a fuse block is just a fuse block.
