Therein lies the source of most electrical problems, not only Opels. A good ground is necessary, as well as a power source for trons to flow. If you were to trace the ground wires from the speedo, you'll find the ground is actually made at the stud that holds up the fuse panel. Which is why it is important to have a really good chassis ground from the battery. Rust and corrosion at the grounding points can wreak havoc on any car. To amplify further, the ground for the headlights is next to the MC forward of the radiator support. Check those for corrosion, rust and tightness too. HTH.
