Unanswered: Fuse pull?
Detritus Maximus
When disconnecting the four colored plugs, you squeeze the little tabs on the top and bottom and gently wiggle the plug. Sometimes it helps to push in on the plug a little to reduce the friction and free up the plug. Also, you may be able to get a couple of fingers up into the fuse box and give a little support to the fusebox side of the colored connectors, especially when you go to reconnect them.
And as always, disconnect the battery negative cable.
Detritus Maximus
We're talking about the fuse box....you can't be overly cautious.
Saturday brain-fart:
Wondering if a little application of dielectric grease around the perimeter of connector housings might help future disassembly. I would keep the grease directly away from the electrical contacts. I might try it next time I have a reason to pull connectors on fuse box. Owner of broken GT fuse box that eventually requires replacement! |
Why keep the grease away from the contacts? Isn't that what it's made for?
BTW the fused came out of my box fine. I'm trying really hard not to break things as I go about fixing them.
Lindsay, send me a PM, I can give you an idea for a power panel replacement, easy to build,
#8 (permalink) | |
Dielectric Grease
If the grease conducted electricity, it would allow the tracking to ground of the power or signal being conducted. I use very little dielectric grease in applications; don't glob it on the area. Used grease for 12v bulbs to ease removal and mininize corrosion. |
I just started using grease more often, mostly on my latest Opel project, I've been greasing every connection I've messed with. Maybe I should stop that practice?
Dan, there are two studs behind the instrument panel pointing down and there should be two holes in the fuse panel that go over the studs and it's held in place with a couple of washers and nuts. The front end of the panel slips into a lip and that holds it up at the front. Also there are some brown wires (grounds) for the entire instrument panel ground and headlight relay, that are also attached to the studs. HTH.
One problem I had was the lip on my fuse panel was broken off so I replaced it with a plastic plaster board applicator. Just trimmed it to size and drilled a couple of holes and pop rivited it to the fuse box. Worked like a champ.
Texas Opel Preservation Society Last edited by baronbors; 03-02-2007 at 02:03 PM. Reason: stupid spelling |
