I have the same problem, but I bought my car with a broken speedometer. I took a look behind the gage pannel and it appears that several electrical connection pins are broken off. I assumed those were causing the problem, but I don't know for sure. I'm a noob.
-Conrad (1971 GT) |
#3 (permalink) | |
The speedometer is completly mechanical. No electricity required except for night illumination. Your best bet is to get one off of E-bay. They pop up often.
A local speedometer shop should be able to repair the speedos, after all they are just mechanical gear boxes inside with a rotaing magnet that drive the needle and the odometer. As for the broken male spade lugs on the back case, they are just the common ground connections for the rest of the instruments and lites. HTH.
Viking
Real Name: Hallgeir
My speedometer has a rather loud "clicking" sound in it, that makes me crazy sometimes (I hate unwanted noise in the car), and it also shows too high speed, around 70 km/h when driving in ~50 km/h. Anyone knowing what that sound is, and could the wrong speed indication have something to do with the drive on the gearbox? I think I`ve read somewhere that there are two types.
The wheels are 185/70-13.
Hallgeir Opels now: -69 GT 1900, -95 Omega B 2,5 V6 CD Aut. Previous Opels: -91 Omega A 2,0i, -85 Ascona 1,6S CC, -78 Ascona 1,9S, -81 Commodore 2,5S Berlina, -82 Ascona 1,6S CC, -78 Ascona 1,9S, -72 Ascona 1,6S http://www.opelgt.com/forums/vbgoogl...4650269&zoom=5 Last edited by hallgeir; 04-05-2007 at 05:43 PM. |
I am also using 185/70-13 tires whick equal OPEL OEM 165SR-13 tires. My speedometer appears to be correct MPH, but cable sticks under 25 MPH and vibrates (when touched). Installed new speedometer cable from OPGTS several years ago; lubricated, but still did not resolve sticking/ vibration. Thought of installing extra speedometer purchased from eBay, but not yet. Might try local repair shop as suggested, whenever old speedo is removed. Or ... if VDO repair shop can repair GT clock, I would think they could remanufacture/ repair speedometer. Might have to send VDO email to inquire? |
Destiny is to Fly
Real Name: Harold
Speedo Numbers
I have a 71 GT as well. Picked it up in August 2006. The PO had changed the speedo because it wasn't working. He put in a speedo with W=897 that he bought on e-bay, but it doesn't read the right speed, seems to be too high. He gave me the original speedo which had W=1062 on it. So I'm assuming the W=1062 is the correct version. BTW, the transmission in my GT is the manual, don't know if an automatic would have the same head unit.
Harold. |
Destiny is to Fly
The speedo in mine is also a W 897 with a manual 4 speed. I've got a spare W 1062 hanging around. Don't really feel like pulling the dash to replace it. So I guess I'll just continue to drive around doing 90, even when I know I'm only doing 70. Really makes me wonder how fast I'm really going when I'm hitting 130??
Must keep my passengers wondering when they gaze over and see the speed at 90 as I zip around a cop on the highway.
Real Name: Harold
I have an extra W=1062 speedo as well, but haven't had the ambition to pull the dash for the swap. Besides it's still too cold up here in Canada, it decided to snow for Easter
www.opelgtworld.de
Here is a short article, which I wrote some time ago for the German Opel GT Group. Perhaps it helps someone...
Ich habe schon einigen Tachos neues Leben eingehaucht, aber diesmal habe ich es für euch fotografiert. Vorsichtige Menschen sollten mit dem alten Meilentacho üben. Zuerst muß der Chromring vorsichtig geöffnet werden. Dazu nehme ich einen kleinen Schlitzschraubendreher und biege die umgebördelte Seite Stück für Stück auf. Das geht mit etwas Geduld sehr einfach. Man sollte nur nicht versuchen, den Chromring abzuhebeln, da man sonst die Glasscheibe zerbrechen kann. Also schon rundherum aufbördeln. Das sieht dann so aus: ![]() Aus dem Gehäuse mussen hinten die zwei kleinen Schlitzschrauben herausgedreht werden: ![]() Nun kann man die Mechanik herausnehmen und das Gehäuse beiseite legen: ![]() So sieht die Mechanik mit dem Ziffernblatt aus: http://img300.echo.cx/img300/9702/p61700160fg.jpg http://img300.echo.cx/img300/6486/p61700189ji.jpg Das Ziffernblatt mit seinen "Ohren": http://img300.echo.cx/img300/8537/p61700201ln.jpg Hier ein Blick auf die Tachonadel, die ich bisher nur ein Mal entfernen musste, weil ich ein anderes Ziffernblatt eingebaut habe. Ich habe mir einen kleinen Holzstab mit einem Schlitz angefertigt und konnte die Nadel damit vorsichtig abhebeln. Im Normalfall kann man sich aber diese "Zitterpartie" ersparen: http://img208.echo.cx/img208/2140/p61700218ls.jpg Un hier der Nadelanschlag, an den die Nadel hörbar anschlagen muß, nachdem man sie mit dem Finger auf "40km/h" bringt und dann losläßt: http://img208.echo.cx/img208/3522/p61700228by.jpg Und wenn wir schon Mal dabei sind, wird der Kilometerzähler auf "Null" gestellt: http://img208.echo.cx/img208/7008/p61700240jc.jpg Wer im Inneren seines Tachos mehr Technik erwartet hat, wird enttäuscht: http://img227.echo.cx/img227/7996/p61700254to.jpg Das ist der Antrieb des Kilometerzählers: http://img227.echo.cx/img227/2981/p61700266zt.jpg Damit wir den Zähler schnell auf "Null" stellen können, wird die Antriebswelle herausgenommen, indem man vorsichtig das Blech des oberen Lagers nach oben biegt: http://img231.echo.cx/img231/9353/p61700438hi.jpg Die Antriebswelle aus Kunststoff kann nun herausgenommen werden: http://img231.echo.cx/img231/2160/p61700453la.jpg Ich habe es bisher immer so gelöst, dass ich einen Schlauch erwärmt habe und ihn über das Zahnrad gestülpt habe. Dann kann man mit einem Akkuschrauber den Kilometerzähler in kurzer Zeit auf Null stellen, da wir jetzt die richtige Übersetzung haben: http://img231.echo.cx/img231/8560/p61700498da.jpg Die Probleme mit der "tanzenden" oder "hängenbleibenden" Tachonadel hängen meistens mit einer gebrochenen oder schlappen Rückstellfeder zusammen: http://img122.echo.cx/img122/2495/p61700379cc.jpg ...oder mit den üblichen Verharzungen durch altes Fett, das auch durch die Tachowelle nach oben gefördert worden sein kann: http://img122.echo.cx/img122/1305/p61700537jz.jpg Ich entferne diese Verharzungen mit einem vorsichtigem Strahl Bremsenreiniger und gebe dann etwas Balistol auf die Zahnräder und Lagerstellen. Dann sollte der Tacho wieder so funktionieren, wie wir es von ihm erwarten. Im Moment bin ich dabei Meilentachos auf Kilometertachos umzubauen, aber dazu später mehr. Ich hoffe dies war halbwegs verständlich und hat euch ermutigt eurem Tacho auch mal selbst zu Leibe zu rücken. Gruß Norbert Opel GT World
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)" |
Viking
Real Name: Hallgeir
Sure helps..
Thank you very much, Norbert. That is a good article. When I read it, and saw those photos, I remembered that I opened up the speedo in my Ascona A, 27 years ago. With that in mind, I will try to do the same again. My speedo doesn`t have a code at the front of it. I couldn`t see at the back of it, have to get the car out of the garage first to be able to crawl under the dash. It`s on jack stands at the moment.
Speedometer Bench Test
I have my gauge panel out and I'm switching out all PO's makeshift wire fixes and testing the switches. When I last drove my car, I remember the speedometer not working. It was sitting on the pin and would bounce up every once in a while. The odometer worked, but it seemed a little off but I'm not so sure. I put a nail in a screwdriver and stuck it into the speedo cable slot and it moved the odometer VERY slowly. How do I test the speedometer? How much does a shop make you pay to look it over?
-Conrad (1971 GT) |
Cable? It's mechanical only as I understand and if the cable begins to give up the ghost then it bounces. Mine bounces crazy at anything under 15 MPH but is fine above that. I read somewhere that the individual strands of the cable fray and catch up on the housing or something. Just a guess. Try running penetrating oil down the cable housing?
http://www.opelgt.com/forums/1e-othe...t-working.html
"Being ignorant is not so much a shame, as being unwilling to learn." Benjamin Franklin Last edited by jvandyke; 06-18-2007 at 06:35 PM. |
I took my speedo apart to reface the gauges. Now it doesn't work right. After the first install it wouldn't register anything until I got to about 60 mph, then it showed 20. I took it back out thinking I had put the needle back on with too much preload on the spring. This time it's much better but "flutters" a tad and isn't accurate, now reads high. Is this just a trial and error thing or is there a method to it or have I baked the thing? This last time I gently placed the sleeve of the needle shaft on the back of needle just barely on the shaft itself at a position just a bit below the pin then gently lifted the needle over the pin and pushed the needle on all the way. Maybe this time I have too little preload? The needle would just barely be held against the pin when at rest.
I did check the thing out and all seems well, nothing appears bent, the "can" didn't seem to contact the magnet. BTW just how does this thing work and is this a common design? Seems a bit delicate (of course it wasn't made to be taken apart by an amateur mechanic 38 years later either). I translated the above german but couldn't make out much to help me.
"Being ignorant is not so much a shame, as being unwilling to learn." Benjamin Franklin Last edited by jvandyke; 01-10-2008 at 09:29 AM. |
The operation of the speedo is fairly common. The cup or magnetic plate rotates, via the speedo cable, which in turn drives the opposing unit by the magnetic field, which is held back by a spring and attached to the pointer. The faster the unit spins to more it drives the other piece against the spring and moves the pointer higher up the scale. If the residual magnetism in the plate gets depleted for one reason or another, the speedo no longer functions.
#18 (permalink) | |
PS note to self: when working on dash and electrics at least secure wiring enough that your foot doesn't dislodge the fuel pump wire in the middle of heavy traffic in heart of downtown highways! Luckily I coasted off a conveniently placed off ramp and knew what I had done so fix was easy but no less nerve racking.
Sometimes these speedo cables dry out
Sometimes in dry or dusty climates those cables can dry out and then they die pretty quickly. I had a relatively new cable which was dry and I had the bouncing speedo needle. I found that the Harley Davidson folks have some great cable lubricants in a spray can, which force lubricant down along the cable and that solved my dry cable problem.
NYAsconaGuy |
#20 (permalink) |
My cable's okay, at least it powers the odometer fine and the speedo is working, just not great. I confirmed from mile marker timings (and I stumbled across one of the roadside digit speed checkers the cops put up so I made 4 passes) Speedo reads about 7 mph high. Guess I'll try to put the needle back on with a bit more tension this time. I did find a couple shops willing to fix or calibrate the thing.
Speedometer & Odometer Repairs — Overseas Speedometer doesn't say Opel but I emailed and asked and he said if it's VDO they'll do it. then this one closer to me Bob's Speedometer - Repair & Restoration of Speedometers, Clocks, Tachometers, Gauges and Sending Units They said I can ship it in for estimate and if it comes out too high they'll ship back free. The first one suggested driving along at a known speed (with a pace car) and push the needle on right at a known speed. Guess you reassemble everything on the gauge but the glass and mess with it, than make adjustments and put it all back together again. Next time I take apart a good accurate speedo, I'll remove the pin first, note where the needle retracts to, mark it, then reverse the process on reassembly.
"Being ignorant is not so much a shame, as being unwilling to learn." Benjamin Franklin Last edited by jvandyke; 01-11-2008 at 12:04 PM. |
#21 (permalink) |
Here's another method I dreamed up that probably wouldn't work but is worth tossing out there.
Make an attachment to a variable speed device (drill, dremel) put speedo on the bench with attachment and use device to simulate spinning cable. Adjust speed of drill/dremel until odometer is turning at a given rate: one mile every minute. Check needle reading (should be 60mph), stop, reposition needle. Repeat. But I think the speedo cable spins clockwise as you look down into it, CCW from the backside view as attaches to housing, whereas my Dremel spins the other way, so I'd have to reverse it, not sure you can, or use a drill but that's hard to maintain a constant speed with..... Good thing winter has returned and I've got plenty of time to ponder.
#22 (permalink) |
UngerDog
That sounds like it would work very well. The drill needs to be in reverse mode (I don't think dremels or roto tools go in reverse though). Getting a drill to go at exactly 1 mile a minute might be kind of hard because they are just not that finely tuned adjustable. Another way to adjust the needle would be to set the drill at a constant speed close to 60 mph and then see how much the odometer turns in a set time i.e. 1 minute. Most drills have a set button to hold the rpm's or you could use a zip tie if yours doesn't. If the odometer turns .9 miles in 1 minute, but your needle was showing say 65 mph instead of 54 mph (.9 X 60 = 54), adjust the needle and repeat for accuracy. If you increase the time of the test you will get better accuracy. Jerry
#24 (permalink) |
V D O Agent
The local VDO agent (Parrott's Instrument Repairs) charged me $80 to dismantle, clean, re-lube and set a spare GT speedo to the milage of my car.
Looks like new ... and they guaranteed accuracy +or- 2% - thought that was pretty good value. You can find VDO agents by searching the Web for the VDO website and there is a 'find-your-nearest-dealer' thingie there.
#25 (permalink) |
UngerDog
If you try it yourself, fight the urge to spin the speedometer too fast. I had a tooth blow out of the odometer once as I tried to hurry up the process of resetting my odometer to 0 miles.
Jerry
