Unanswered: Rear Light Wiring for GT
I realized what the wire is shortly after I made the post. My GT harness is from a '73 which had TWO back up lights, one in the center of each rear light. The lights I am using are early lights with no backup light. The backup light is a single unit in the center of the rear, so only one wire is needed. I am just capping off the extra wire.
I'm having a similar problem with my rear lightes.I chromed the bumperetts & replaced some lenses & all the bulbs.Every thing is working except that when I put on the brakes the left brake light goes out.I've anilized the wiring diagram for my 71 gt & a couple wires have me puzzeled.This is the left stop light..The diagram shows a double blackyellow & a gray black.What I have is a single blackyellow & a double grayblack ?The only area that could be the greyblack double is the lr side marker.Tried that & it made things really mixed up & had to really pull the wire so it didn't feel like the right fit anyway.I know this sounds confusing but I'm running out of possible solutions. Is there a mistake in the diagram . More than likely me I'm sure.All bulbs & fixtures are in perfect working order/ Help
The wiring back there is actually very simple, you only have markers, brakes, backup, blinkers, and a couple of wires that go through the harness and then connect to a short wire that goes to the dome lamp. I drilled two holes and installed two stainless steel screws as good grounds inside the car right behind the gas tank. I ran all my grounds to the two studs, one on the left and one on the right, I ground off the paint and then used dielectric grease to make a good connection and also inhibit rust. If you have to you can disconnect the + at the battery, pull the connectors out of the fuse box and then run a test wire from the positive of the battery and touch it to the proper terminals in the fuse box connectors, then all the lights can be tested, it becomes very simple because all the wires run straight to the back of the car, that is how I did it a few weeks back when I was doing my electrical system. When I plugged in the dash everything worked the first time
. Just follow the schematic to determine which terminals do what.
#9 (permalink) | |
To help you out on tracing the wires, Here's the color codes for the rear lites from my DESTEC schematic.
Left Parking Lites: Gray/Black Left Turn Lite: Black/White Left Brake Lite: Black/Yellow License Plate Lite: Gray/Green Back-up Lite: White/Black Right Parking Lites: Gray/Red Right Turn Lite: Black/Green Right Brake Lite: Black/Yellow Just to clarify one thing, only the brake lites have a dual element bulb, they should have the pins on the sides of the bulb offset so they can only be installed one way. You may want to double check the connections on those lites to be sure you have the right wire on the correct terminal. HTH.
