gone Opel GT crazy!
Unanswered: tachometer questions.
i'm guessing it's a electrical tach but where do the wires go to make it start working? i have pics here http://www.opelgt.com/photos/showpho...2/ppuser/21743 what does the green wire do? http://www.opelgt.com/photos/showpho...1/ppuser/21743 http://www.opelgt.com/photos/showpho...0/ppuser/21743 what does this smaller green wire do?
Rex {Elda} "code green"1969 Opel GT 4 speed,Weber carb,Pertronix electronic ignition. 1972 parts car auto-RIP 1972 parts car -Rip {saphire}-1993 yellow nissan pick up 5 speed! 1993 red nissan pickup automadic (unamed for now) {Alexia}-1989 chevy camero {Elliott}-1978 Pontiac Firebird -1989 Ford probe(unamed for now) 17 years old -6 vehicles... and still moveing on ![]() WATCH OUT,I'M A OLD CAR FANATIC!!! ![]() Future wanna be concept and custom car designer/builder. |
http://www.opelgt.com/photos/data/52..._Schematic.pdf
Try this link, it should take you to a color schematic that I posted for a '73
According to my DESTEC schematic, there are three male spade lug connections. Two close to each other and one by itself. The one by itself is a Red/Black wire that powers the tach and comes from the positive terminal block between the speedo and ammeter/oil gauge. The center wire is the Green one that goes to the coil negative side via the Green IP connector Pin #3. The last one is a ground Brown wire that connects to the ground lugs on the back of the speedo. HTH.
gone Opel GT crazy!
thanks guys, i'll see if i can get it working
Adjusting tachometer
Is there anyway to adjust the teachometer-zero it out, I'm running at 1800 rpms with the engine off!!!
Dave 73 Opel GT-work in progress 74 Manta 75 Manta Previous 72 Manta Rallye-owned 1974-1979 |
You can pull the needle off the post and put it back on at zero. Just make sure the post doesn't turn while you put the needle back on. Internally, there is an adjustment for the electrical circuit board. HTH.
