Unanswered: Opel Tachometer Board
Ron 72 GT 3.4L V-6/T-5/ZF posi - almost done - Just need AC installed. ![]() 75 Chevy monza 5.7L/TH350/Auburn 3.08 posi - Next Last edited by namba209; 02-11-2008 at 07:59 PM. |
If you also want to make one for the Manta, I'm in.
Dieter
Thanx, Tom, I misplaced the original tach board, can't find it anywhere. I sure don't want to pull the instrument panel and tach if I can help it.
Dieter, these boards are just gonna have printed circuits on them, you'd have to purchase the components and solder them to the board. Kinda DIY for those that can't use the Opel tach in their application.
Mount hole Center to Needle center is 14 mm, to mount hole center 14 mm -mount to mount is 28mm, the center hole is 17 mm, the post (mount) holes are 7 mm hope that is what you need. I will go and see if I have a Manta and a Kadett torn down.
Just went and checked they are all the same, Manta, Kadett and Ascona
rk 68 Kadett 2 Dr 1.1 SR/Rallye Suspension 68 Kadett Rallye 1.9/4 Spd & AC 69 GT 1.9/4 Spd 70 GT 1.9/5 Spd,87 Impulse PB/MC/4 wheel 10.5" vented Disc/complete suspension/power assist & tilt wheel steering 71 Kadett 2 Dr 1.1/4 Spd/4 wheel drum brakes(project:to a 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc, Factory AC from Buick/Opel by Isuzu 72 GT 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc 73 Manta Rallye 75 Ascona 1.9 FI/5 Spd/Impulse rr Disc brakes OPEL WERKS Last edited by Killer Texas GT; 02-11-2008 at 11:33 PM. Reason: went to check the other tachs |
Hey, that's good news Rodney, and it is exactly what I needed. It means folks that are contemplating or doing an engine swap in those models won't be left out in the cold, so to speak. One question for you. On the circuit board I got from P.J. Hall, the nylon bushings for the mount holes kept falling out, but the flanges held them in until I turned the board over. Can the holes be made a silly milly smaller or is it possible my holes were a tad larger than 7mm? Just an eyeball guess would work here.
Ron, when I took the face plate off the nylon "bushings" set on top of the board and the face plate screws when installed hold the nylon "bushings" in order to hold the board down and in place. I can get a picture of the nylon spacer for you this evening when I get in from work. The holes in the board could be made smaller as the mount dia. is 6.4 mm and the centre where the needle isolator board is measures 14.6 mm, both these measurements are tight with no room for error. Note the nylon busing flares out to 10 mm, the inside dia. of the busing is 6.89 mm the outer is 7 mm with the mount hole in the board 6.9 mm and the centre hole tight is 16.76 mm. These last set of measurements where taken using a plastic caliper, while the previous measurements where taken using a ruler. The center to center dimension are correct by both ruler and caliper. Let me know if you need a picture of the nylon spacer/"bushing".
rk 68 Kadett 2 Dr 1.1 SR/Rallye Suspension 68 Kadett Rallye 1.9/4 Spd & AC 69 GT 1.9/4 Spd 70 GT 1.9/5 Spd,87 Impulse PB/MC/4 wheel 10.5" vented Disc/complete suspension/power assist & tilt wheel steering 71 Kadett 2 Dr 1.1/4 Spd/4 wheel drum brakes(project:to a 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc, Factory AC from Buick/Opel by Isuzu 72 GT 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc 73 Manta Rallye 75 Ascona 1.9 FI/5 Spd/Impulse rr Disc brakes OPEL WERKS Last edited by Killer Texas GT; 02-12-2008 at 08:59 AM. |
Thanx Rodney, I don't need a pic of the bushings, you answered my ? about the hole diameter and the bushing OD. Mine were slotted lengthwise and I guess had lost the "spring" tension and kept slipping out of the hole. So a 7mm hole to put a slotted 10mm bushing in, works just fine. Thanx again. I'll pass the info to Nathan, so he can layout the components for the PC on the boards.
