Old 05-26-2008   #1 (permalink)
highschoolopelproject
littleD55555 is on a distinguished road
Question Unanswered: Horn Button Confusion
I have followed the power all the way to the brown wire going into the horn button. so it is a problem with the button can someone send some pictures of the horn button (complete) and explain how it works
thanks
littleD55555 is offline
Old 05-26-2008   #2 (permalink)
Don't have pics, but there is a copper ring mounted under the horn button that contacts a plunger and spring. When you press on the button the copper ring makes contact with ground through the steering shaft and the horn goes off. The copper ring is insulated by plastic sleeves that the mounting screws go through. HTH.
Old 05-26-2008   #3 (permalink)
GTer
pecje's Avatar
Real Name: Patrick
pecje is on a distinguished road
thanks
Maybe this article can help you: http://www.opelclub.com/SteeringColumnApr2006.pdf
Definitely EX-member of the MWTE! © Mr. Corey Suggs
pecje is offline
Old 05-26-2008   #4 (permalink)
Question
ok I have everything but the plunger and spring. I have three screws with springs and the copper ring but there is no plunger and spring contacting the copper ring connecting it to the inner ring. Can I make one on the laith? Does anyone have a pic of the plunger and spring that i can use to design a new one? Or can i take one from a different car?
Old 05-26-2008   #5 (permalink)
What stops the plunger from grounding on the side of the hole it goes in. Is there a plastic tube it goes in? (to stop it from gounding)
Old 05-27-2008   #6 (permalink)
tomking's Avatar
YES, the plunger is inside a plastic sleeve, along with a compression spring.
TMK
tomking is offline
Old 05-27-2008   #7 (permalink)
ok thanks, I ll whip one up on the laith, sould be really easy, i have thought of a design, but it will trial and error to get it the right length
Old 05-28-2008   #8 (permalink)
Exclamation
ok well I made the plunger and it worked fine for about one honk then stoped. Its not the horn button anymore (I think) its the horns all there is, is a clicking sound coming out of the horn like something is jammed. I know that it not the button because I used a peice of wire to ground the horn and it did the same noise. Can the horn be taken apain and cleaned, or is it a solid unit? sould I spray the inside with wd40?
Old 05-28-2008   #9 (permalink)
tomking's Avatar
There is an adjustment screw/bolt on them. But yes they can also be taken apart even though they are riveted together. It is a really simple mechanism. The adjustment screw is for tone adjustment and you might try that first.
TMK
tomking is offline
Old 06-01-2008   #10 (permalink)
Cool
finally got the horn working took them right out of the car and drilled out the rivets. the inside mechanisms must have been totally seized because I used some WD40 on it then taped the residue out and rivetted it back together and they work fine
