Real Name: Anders Jönsson
I will be getting there soon, my tach is not operating at all with the EDIS4 and the MegaSquirt. When I figure it out I will post my answer, may take me a few days.
Resistance?
I had similar problem with another type electronic module replacement for points, tach would be erratic, ending up having to add resistance to the coil the extra load cleared the problem up.
Hi.
Did you try pin 2 on the EDIS? Cut and paste from the meagmanual... You may be able to use the IDM (Ignition Diagnostic Monitor) output to drive the tach. IDM a signals that the primary side of the ignition coil has fired. Simply wire the IDM output (pin 2 on all the EDIS modules) to the tach input Garry |
Yes both 2 and 11 pin on the edis modul with zero result pin 2 works fine on my friends kitcar but it is a different kind of tacho. I found the exact way on a homepage where someone with a old BMW described how to get a old tacho to work but the link is no longer working.
#10 (permalink) | |
Anyway back to the tach if you cannot find a solution take it to a shop that has a method to look at the output of the electronics your using for the tach and look at signal if it is not discreet you are going to need to add some load to make the system respond as a coils and points would. I can remember a specific problem with magnetic speed controls we had incorporated some newer processor electronic controls, the system did not work we had to actually add a relay ( it created a load) to the out signal and use the contacts to give the signal to the old pre existing equipment. there is always a way around technology I believe if you get a scope and actually looked at signal you would not see a crisp return to zero, I think you would see random voltage levels before new high is hit. It appears to tach the the level maintained is zero and the increase is based above that reference that why tach floats around and bounces. JM2CW |
#11 (permalink) | |
I thought I had saved some info on something simular, but can't find it now. Do this pictures look familiar. I'm sure there is someone at the megasquit forums who will know what we need. |
I remember it too now. It crossed my mind what they did to the BMW could transfer to the Opels. I recall it being a VDO gauge. If you still have the url of the web site we would could try the way back machine.
#14 (permalink) | |
I don't have one of these units so I can't be positive but just from looking at that drawing that circuit is using 22 volt rectified signal (diodes passing a positive pulse from the coils) firing a zener diode and dropping the supplied voltage from the coil across the pull up resistor 100 K.
Zeners work in the negative curve (reversed biased thats why it is drawn in circuit what appears to be backwards) they deliver at their rated voltage. one area you might look at if your coils are actually 12 volt not 22 volts the pull up resister is 100K and that 1N4748ADICT zener is rated for 22 volts @ 11.5 ma seems to me to be the wrong zener diode t (unkess the coils are actually being fired with a 22 vdc signal). I don't think that circuit is turning on the zener . 1N4742ADICT zener is rated for 12 volts @ 21 ma when the circuit is working correctly, the voltage path is through the pull up resistor, it developes the voltage dropping the postive signal from the coil across the resistor, the tach sees what ever that voltage is across the resistor electrically I don't think the zener is working correctly in that circuit if the coils are 12 vdc. Once the circuit is firing and turning the zener on, the only thing left to play with is resistor size to develope the right load (voltage) for the tach to respond to. http://dkc3.digikey.com/PDF/T081/1261-1267.pdf look at the values Just some fuel for thought while sitting at work looking at that diagram. |
Anders, don't know if you have seen this part of the msefi site but it is how I learned how to configure the EDIS unit and connect it to MegaSquirt. The very bottom of the document has info on how to connect a tach to the EDIS module if you are having problems. The connection diagram is exactly as you have previously tried but the part numbers are different, here is the link to the EDIS page.
#17 (permalink) | |
#18 (permalink) | |
no you are correct 1N4746ADICT
I didn't mean to confuse I like to work on electrical problems and I was playing with that diagram this early morning at work I was putting expected signals on it and the assumed value of 22 volts didn't appear to be right, I was sure that was going to be the answer so I put it out there. I don't see a purpose for the zener unless that zener is being used to change a positive going saw tooth wave input from the rectifying diode thats triggering it to a more square pulse at the 18 volt mark. It's purpose appears to act like a gated transistor, Only suggestion I would have left without a scope signal is are your coils seeing a 18 volt pulse to be triggered? |
I was afraid that the answer to my question would raise even more confusion than before i would like to explain that i don't know anything about electronics. my hope was that someone who are using edis ignition and got there tacho to work would explain or show there wiring diagram and what components they used. I am grateful that people take their time too try to help me but i need info that is so precise that a child would understand it.
#20 (permalink) | |
#21 (permalink) | |
Don't know if drawing helps or not signal 1 and 2 are being applied each 360 degree rotation of the crankshaft signal 3 is the signal of both coils see how it is 4 pulses signal 4 is where I think your problem is your not getting the output from the zener the zener is set for 18 volts it is not turning on. My time is of no issue I'm at work trying to kill time can't speak for anyone else. Due to the nature of the beast the actual signals with coils being inductive may vary it is just for illustration. Signal point 3 and 4 is where you would look to see what the circuit is doing with a scope. Only difference should be the look of the pulse, timing will be exactly the same. Feel free for anyone to correct me. |
#22 (permalink) |
Stopped at Radio Shack on the way home and picked up 1N4004 and 1NT4742 which is a 12V Zener, probably won't have time to play with them until this coming Saturday.
#24 (permalink) |
I assembled the circuit exactly as shown in the EDIS portion of the msefi.com site and my tach works perfectly. All the parts were purchased at radio shack and I had a small piece of universal circuit board laying around from my college electronic days so I soldered it all to that with 1/4" tabs sticking off of it to be able to attach push on terminals to it. The circuit board is about 1 1/4" square, I just have to waterproof it and voila! Anders I don't know why your tach will not work, maybe it is the tach itself. I did use the 12V Zener and it does work during cranking, but even if it did not I don't think I care about cranking RPM only need the tach when my baby hums
#25 (permalink) |
Thank you so much for taking your time to help me! I know that the tacho is ok tried it with a signal from my fathers ascona and it works ok. I will get new diodes and solder them in and check if this will work.
