Old 08-18-2008   #1 (permalink)
Hoosier Opeler
rrossjr's Avatar
Real Name: Ron
rrossjr is on a distinguished road
Answered: Bouncing Temp Gauge
I just noticed something strange last weekend when I had the GT out on the highway. At speeds of <65 mph, the temp gauge works normally (steady reading at a little less than 0.5) However, when I run the car up to 70 mph (or more...) the gauge starts to oscillate between 0-1. When i slow down, the reading is back to normal. Anyone else ever seen this?
Ron in Indy
Oh yeah, for what it's worth, the fuel gauge (and all others for that matter) seem to be working normally.
Cheers,
Ron in Indy
rrossjr is offline
Most Helpful Answer - Posted by BQS4
I'd check to see if the wire coming off the sender is secure. Had mine do that once, found the wire loose. At normal low speeds worked fine, but, at higher speeds, wind would buffet the wire and the gauge would bounce.
Old 08-18-2008   #2 (permalink)
Old 08-18-2008   #3 (permalink)
Hoosier Opeler
rrossjr's Avatar
Real Name: Ron
Thanks Gene,
That sounds reasonable, since it doesn't seem to be RPM related (only MPH)
I just had the @%&**~! instrument panel off last year to fix the speedometer. I will probably live with it until something else breaks back there.
Ron in Indy
rrossjr is offline
Old 08-18-2008   #4 (permalink)
Originally Posted by rrossjr View Post
Thanks Gene,
Ron in Indy
Ron,
I meant the sender in the engine compartment, on the thermostat housing.
Old 08-19-2008   #5 (permalink)
I had one that was doing weird things also. It turned out that the sending unit had gone bad. You could wiggle the terminal slightly.
Old 08-19-2008   #6 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Real Name: Matt
I happened to notice that the FSM says to drain all the fluid out of the radiator to change the sending unit. It seems like that wouldn't be necessary. Is this just another FSM quirk?
Matt
'72 Opel GT (Fireglow Orange)
Restoration Thread
Comments Thread
Other Cars:
newman27 is offline
Old 08-19-2008   #7 (permalink)
Matt
Yep....
Old 08-19-2008   #8 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Real Name: Matt
Yep....
It figures... I know they didn't have PCs and Word Processors back in the early '70s when these manuals were being written, but there sure seems to be a lot of "cut and paste" errors...
Restoration Thread
Comments Thread
Other Cars:
newman27 is offline
Old 08-19-2008   #9 (permalink)
jlthunder's Avatar
I had a similiar issue. As Gene stated, check the connection at the thermostat housing. I had to put a new connector on the wire as the old one was so brittle, when I went to tighten it, it broke. A standard spade connector works on both styles. The one with the round connection and the one with the spade connection. Good Luck
1973 GT, Parted out, R.I.P.
jlthunder is offline
Old 08-19-2008   #10 (permalink)
Hoosier Opeler
rrossjr's Avatar
Real Name: Ron
Ron,
D'oh! Of course, that makes more sense. I'll go out and check it later tonight. The good news is that I get to drive the car hard to "check the repair"
Cheers,
Ron in Indy
rrossjr is offline
