thescifiguy
Real Name: Gordon Payton
Answered: Horns chirp once
What's my likely cause? Low voltage due to dirty contacts at either the button or the horns? Isn't there a relay that occilates the horns?
Most Helpful Answer - Posted by markandson
| I doubt it is a short, things would be melting or arcing if it was. Corroded connections seems likely to me. BTW I did add a horn relay to my GT and the horns work great. The new horns I bought were higher power than the OEM ones and I wanted to make sure the circuit could handle the power. |
#2 (permalink) | |
Horn button is ground (negative). I don't have my wiring chart at work, but GTs' did not use a horn relay. Sounds like the problem could be the grounding ring (for horn button) in steering column.
thescifiguy
I'll check
I went out and emory-clothed both horn button brass ring surfaces and both ends of the spring-loaded cartridge thingy. Man, I really thought that was it. No luck, still one chirp. It seems that plenty of power is getting through, since the amp meter nosedives nicely to the left when the button is pressed.
I suppose I could remove my new horns to see if there's a hidden adjustment screw, even though I see nothing and the instructions mention nothing. I guess I could run current straight from the battery and they should make noise...right? tick-tock...tick-tock..... Okay, I just went out, removed one horn, and jumped power from the battery to it. Honkkk! So, that means the horns are okay. I guess I'll have to do surgery-by-feel tomorrow and reach my hands through the grill and remove/replace the female terminals on the horn wires.
thescifiguy
Good ground
I think I MUST have good steering column ground since the amp meter almost pegs when the button's pressed. I'm gonna hope that my wire terminals are corroded and are making a high resistance connection. I think my previous GT had the same issue 25 years ago. I live in the Land of Corrosion here in Jersey and electrical troubleshooting always begins with the cleaning/replacing of terminals.
Uber Genius
I would put money on a short somewhere between the ground wire feeding the horns and a hot wire along the way.
It is the only reason the AMP gauge would peg like that and not operate, obviously functioning, horns.
UngerDog
May just be corrosion at the terminals of the horn wiring terminals at the horns. If I'm reading your test method right, you're testing for the ground at the horn button. Try using a test light connected to the battery positive side and either ground at the horn. With the key on, you should be able to see the test light glow when you press the horn button. Another test would be to test the positive leads at the horns by connecting them to the battery negative with a test light.
Jerry |
#11 (permalink) | |
You may need to install a relay for the horns to operate properly. Harold |
Opel Intern
It sounds like a continuity difficulty to me. Check the resistance between every section of wire in the circuit. If both of the horns work, it may simply be a crushed wire. It could technically have continuity, but as soon as any power is applied, the bad section of wire heats up, adds resistance, and prevents power from flowing, producing a chirp.
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 06-25-2009 at 09:35 PM. |
Jay, if your stock horns work properly, why don't you do a quick check of how far the amp meter dips when the horns are applied and report back? IIRC it discharges fairly strongly. Now over the years resistance has probably increased because of corrosion and the simplest 'fix' may be to add a relay.
Is the steering column grounded with the additional ground wire that is supposed to be there? I believe an earlier poster alluded to this when asking if the column was properly grounded. I would be sure of this first before anything else. The relay is still a good idea especially if you've upgraded the horns as Jeff did. Harold |
thescifiguy
And the winner is....
I put new terminals on all 4 wires, plugged in just the driver's side one 'cuz it's closest to source and has the jumpers that feed the passenger side horn, pressed the horn button and.......one chirp. After I got done cussin', I fished the old horns out of the recycle bin and plugged one in. HONK! Plugged them both in. HEEONK!
So, short of running new wire throughout and grounds, it looks like MARKANDSON is the winner with the closest to best likely answer: The new horns are higher power than the OEM ones. Just for everyone's information the horns I bought were MAXI SOUND 320-2T. They're red/black plastic with chrome outlet covers and chrome support bars. I still like them a lot(because they match the color scheme of my car), so I'm gonna pop a relay in there when I get a chance. Thanks for all your suggestions guys!
#18 (permalink) | |
Harold |
#19 (permalink) | |
Mid-West Opeler
How about fuses........
#20 (permalink) | |
Uber Genius
Yeah, a good idea to toss a fuse in there as well. Between the battery and the relay would work fine but make it a hefty fuse.
Also, I would suggest a solid state relay as opposed to a mechanical one. That way you could mount the relay near the horn to 1) save wiring since you can use the horn wires to power the relay, and 2) you can encapsulate the relay and make it waterproof. Mounting the relay next to the horns would be much easier that way. (IMHO) Harold
#21 (permalink) |
Opel Intern
Not too hefty... or there won't really be any fusing going on. Check and see the Amperage draw from one of the horns, multiply by two and round up to the nearest fuse and that would be what I would start with.
#22 (permalink) |
thescifiguy
Let's go relay CRAAAAZY!
Sounds good to me. I bought this GT 1.5 years ago and didn't really work on it at all for the first year, other than to determine that it needed a new engine. I spent the first year buying parts and replacing or refurbishing everything mechanical: ALL new brake system, 2.0 engine, rebuilt auto tranny conversion from stick, totally rebuilt front and rear suspensions. Then I spent every single day until 8:30 at night for 3 months putting it all back together. All so that I could drive to Carlisle. I only got the headlights working at 10pm the night before!
But I haven't done the electrical stuff yet. That's this Fall's project(It's 90 degrees with 70% humidity all Summer here in Joysey). I guess I'll be going relay CRAAAAZY! Gotta put in the starter relay, a fog light relay, and now the horn relay. What other relays can I/should I put in? It'd be nice to have a whole bank of them on a single bracket with an associated bank of fuses to serve them. I'd like to start with a new front lights and horns harness and then the dreaded instrument panel one later. Is it OTTO who sells new wiring harnesses?
#23 (permalink) | |
Hmmmm.....still sounds fishy to me unless the wiring can't carry the current, but then I would expect you to be blowing a fuse. Did you check the connections at the fuse block for the power wires? If not I would check those wire ends too and make sure you have nice clean blades on the fuse block as well. Also check the fuse itself and make sure you don't have corrosion on the tips of the fuse and in the fuse holder. Naturally a relay is probably your best bet but even with that you should be sure you have no lurking gremlins in the circuit or you are just asking for trouble at some time in the future. You also might want to find the wire in the harness that goes up to the horn button and ground it to see if the problem is associated with the horn contact ring.
