thescifiguy
Real Name: Gordon Payton
Unanswered: Ignition switch gray wire?
During reassembly, I snapped off the prong for the red wire on the turn signal switch, but was able to solder it back on. Then I noticed a gray wire, coming out of the bundle of ignition switch wires, hanging loose, and a vacant ignition switch terminal that looked as though something had snapped off of it. So I soldered the gray wire coming from the gray-sleeved bundle of ignition wires to that terminal. I then noticed, as I was installing the ignition switch and lock cylinder, that there was another gray wire coming from the lock cylinder housing that ended up in the vicinity of where I'd soldered the other gray wire on the ignition switch. The wiring diagrams lead me to believe that these wires are part of the "buzzer" circuit. I guess this was a buzzer for seat belts or something. The car never "buzzed" before I did this repair. The original seat belts are long gone. The steering column had been taken apart before by someone, who may have disconnected these gray wires. What are these gray wires for and do I need them? Should I remove the one I soldered to the ignition switch and tape them both off? Should I solder them to each other?
#2 (permalink) | ||
Opel Intern
HTH Last edited by Redskinsjbs; 07-22-2009 at 02:19 PM. Reason: Attatched diagram |
Looks like Jay has you covered with his answer. The gray wire is for the key in the ignition warning buzzer to remind you to take the key out when exiting the car.
Harold |
