Unanswered: dismantaling speedometer
#2 (permalink) | |
HTH, Harold |
#3 (permalink) | |
removing bezel
In one of my old posts on the classicopels site at Yahoo, I described how to run a replacement odometer up to match the current one. The post was published in the OMC Blitz. Here it is:
1) Remove the speedo from the case by prying off the front molding. 2) Remove the 2 screws in the back of the case to get at the mechanism. Be very careful of the speedo needle and is quite fragile. The bearings are small and the coil spring is provides the calibration. 3) There is a nylon shaft running from the first shaft to the odometer wheels. There is a worm gear at both ends of this shaft. Remove the shaft by removing the closest screw on the gear box and by loosening the one on the opposite side. Replace the screws. 4) Then using a short pencil with an eraser in a reversible drill, drive the brass gear on the end of the odometer wheel shaft with the eraser. The drill should be in reverse. You should be able to do about 40,000 mph. To go 29,000 miles took me 2 erasers. I put a drop of clock oil on the end of the odometer shaft to make sure it had enough lube for this high speed run. 5) Clean, degrease, inspect everything. 6) Install the worm gear shaft again by loosening the 2 screws again. 7) Use a high temperature grease to lubricate the gears since you can expect high temperatures in a closed car. A small drop of clock oil in the odometer bearings and the speedo bearings should not hurt either. 8) Make sure the speedo needle moves freely before reassembly. (I am doing this because the one in my car binds at 35 mph even after two attempts to repair it.) 9) Clean the glass and trim ring and reassemble. |
