+ Reply to Thread
Results 1 to 15 of 15
Thread: amp gauge warning light
    GT Smart rbuhler is on a distinguished road rbuhler's Avatar
    Aug 2009
    Winnipeg
    37
    When ignition is off the warning light on the amp gauge stays lit up anybody know why
  2. #2
    Opel Key Master opelspyder is on a distinguished road opelspyder's Avatar
    Tennessee
    1,358
    Check to see if a power wire to the dash is not been placed into the wrong tab of the fuse box. Have you done any wiring work, or changing anything??? The wire that powers the gauges feeds the amp gauge light. It receives its ground from the (blue/white??) wire of the voltage regulator. So for some reason the power supply is on at that time. Is the temp gauge workingas well? I think the gauges would be working as well
  3. #3
    Tennessee
    1,358
    Oh another thought...if memory serves me well, the wire that may be on the hot all the time fuse instead of an ignition on fuse would be (black/red) in color. This circuit powers all the gauges. I would imagine if the circuit is hot, then the gas gauge or the temp oil gauges would show they are working too
  4. #4
    Member timemachine is on a distinguished road timemachine's Avatar
    Jan 2006
    Swarthmore, PA
    834
    I am not a GT wiring expert but I have seen this happen a few times in other cars, including one of my Mantas. If you haven't been moving wires around, I wouldn't worry about that stuff beyond a simple inspection. It's not your ignition switch because a single wire powers all the accessories including the oil light, which isn't coming on.
    What happens is that a leaky diode or cap allows B+ from your alternator to flow back through the light and it then finds a partial ground through the accessory circuit. Even if your car charges okay, and I assume it does, it might well be a faulty voltage regulator.
    Try removing the connector from your voltage regulator (a three wire plug from the alternator) and see if that turns the light off. If it does, it is very possible that your regulator has gone bad. I'd still recommend plugging in a spare or borrowed regulator before buying a new one, but I have seen this before.
    Jim
    '74 Manta ("Sig")
    '75 Sportwagon (project)
    '72 GT (whenever I get to it)
    Sold or wrecked:
    '72 Manta Rallye
    '73 Manta
    '74 Luxus
  5. #5
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,074
    i would second reg pack too , back feed from alt is most common reason i can think of
    B.O.O.B. founding member
  6. #6
    Aug 2009
    Winnipeg
    37
    I just purchased this 3 GT's and have done no wiring I will try using a spare regulator from another GT I have tonight
  7. #7
    Aug 2009
    Winnipeg
    37
    I uplugged regulater light stays on, I'll try power wire from gauge and see if it is connected staight to positive live circuit
  8. #8
    Jan 2006
    Swarthmore, PA
    834
    Again, I don't have a GT diagram but on most cars I have seen, the ammeter GAUGE is always on, key or no key, connected in the battery line to the alternator. Big battery lead goes to starter, smaller lead goes from starter to alternator B+. You could test this by turning your lights on while the car is off to see if the ammeter shows discharge.
    The alternator idiot LIGHT is supposed to show battery discharge only when the ignition is ON (via the regulator). When the ignition is on there should be 12V+ at one side of the bulb whether the car is running or not. The ground that causes the bulb to light should normally come from the regulator.
    BTW, does the car seem to charge and hold a charge okay? I suppose a bad diode in the diode pack inside the generator might also cause this problem. You could disconnect the red wire on the back of the alternator to check, and also make sure you have a good ground wire from the alternator case to engine block in case the field is leaking. (Even though the alternator bolts to the block, it has rubber bushings that insulate it.)
    Don't want to overcomplicate, just trying to help.
    Jim
    '74 Manta ("Sig")
    Sold or wrecked:
    '72 Manta Rallye
    '73 Manta
    '74 Luxus
  9. #9
    Aug 2009
    Winnipeg
    37
    after checking everything out from these posts I found not only is the light on the alt. gauge on, but I have power to my wholeright side fuse panel when ignition is off and my voltage regulator gets warm and in the morning my battery is dead. After checking everything out I found if I disconnect the red wire #10 from the alternator the light goes out and the fuse panel goes dead with key off. What am I missing is this wire in the wrong spot on tne fuse panel or is wire on wrong place on alternator there are 2 spots on diode support
  10. #10
    Jan 2006
    Swarthmore, PA
    834
    Quote Originally Posted by rbuhler View Post
    Now we are getting somewhere. There are nine diodes in the generator, three of which provide an isolated power source to your regulator. That could be your problem. Take out the alternator and have it tested. Most shops, including advanced auto parts do this for free. There's probably an automotive electric store in your area that can fix anything and they're usually pretty reasonable. (I am assuming the regulator has been isolated and is not the problem.)
    The two bolts on the back of the alternator do the same thing. The B+ from the battery is usually connected to the one nearest the engine to keep things tidy.
    Two or three of your fuses will always read 12V to ground so your brake lights, dome light and emergency flashers always work.
    Jim
    '74 Manta ("Sig")
    Sold or wrecked:
    '72 Manta Rallye
    '73 Manta
    '74 Luxus
  11. #11
    1000 Post Club jlthunder is on a distinguished road jlthunder's Avatar
    May 2003
    Salfordville, PA
    2,206
    Quote Originally Posted by timemachine View Post
    Now
    Jim
    Jim your advise is great, but one small correction. The brake lights are on the key. When you turn the engine off, the brake lights don't work anymore.
    Yeah, I know, I'm being picky.
    1973 GT, Parted out, R.I.P.
  12. #12
    Aug 2009
    Winnipeg
    37
    the regulator has been tested its OK I will take off the alternator and swop it with a spare and get this one checked out. And yes no brakes key off.
    thanks for the help
  13. #13
    1000 Post Club wrench459 will become famous soon enough wrench459's Avatar
    Jul 2005
    Milner, GA.
    1,795
    Blog Entries
    12
    Just for grins whats the AC ripple under full load?
    This and that
  14. #14
    May 2003
    Salfordville, PA
    2,206
    swop it
    New term from our friends up North
  15. #15
    Aug 2009
    Winnipeg
    37
    well I finally had time to swop out the alternators and bingo everythink works fine.Now that I have it running off to tackle the brakes, to get it stopping.
+ Reply to Thread
