Unanswered: Oil Pressure Gauge Doesn't Work Properly (was Oilpressure-sensor for the 1.2N engine)
Hello
I'm having a GT 1100, but the 1.1 engine was replaced by an 1.2N engine 20 years ago ... My question to the Opel Kadett B guys: Isn't it possible to put an (1.2N)oilpressure-sensor in this engine? I've putted an oilpressure-sensor of a GT 1900 in it, but that didn't worked. The gauge 'flipped' all the time, and at higher RPM it completely flipped to the max 5 (bar). And stayed there. Now I've putted a used sensor of an 1.3 engine in it, but this sensor seems to be broken. Do you guys have a solution? P.S.: I'm using a GT 1900 oilpressuregauge, I suppose this isn't a problem ( the gauge will give the same oilpressure althought it's a 1.9 or 1.2 oilpressuregauge? ) Thanks Joost |
Detritus Maximus
While I don't have much knowledge of the 1.2N, I twould seem to me that the sending unit should be matched to the gauge. GT1900 gauge = GT1900 sending unit.
The 'flipping' of the needle may have been a problem with the electrical connection, not the sending unit or gauge. |
"No, it's not fiberglass."
"No, the motor is not in the back." "No, your friend in high school did not 'peg' his speedometer." |
Oil Pressure sender
Your problem was that the connection to the pressure sender was the incorrect side. The GT 1.9L oil pressure sender has two connections. One is for the oil gauge and the other is for the low oil pressure lamp on the dash. The marks on the gauge are "G" and "WK". The wire from the gauge unit connects to the "G" terminal and the wire to the lamp connects to the "WK" terminal.
Good luck. |
Oil Pressure sender.
Joost,
Sorry that I did not have the correct answer. If you can find a 1.9L sensor, that may correct the problem. VDO also sells the sensor. If you have a seller of the VDO brand in your area, this might work. Also, they are available at www.egauges.com. The part is expensive, but it is the correct unit for the VDO dual contact unit for the gauge and warning light. Cheers. |
I'm slow but GT is fast
Texas Tom,
Having the wires hooked up in reverse on your "friend's" oil pressure gauge would cause the needle on the gauge to read only "at rest" or "full pressure". This would cause the needle to go almost all the way to the right or bounce back-and-forth at start-up. The oil pressure lamp would probably not have a discernable difference, unless it flickers on and off at start-up. What has "your friend" noticed? I have "a friend" who hooked his up like that also. What a bonehead! You'd think he knew nothing about cars! I can't imagine! |
Detritus Maximus
Not that I ever hooked those wires up backwards,, but when I did, the light acted like it had a dimmer switch when I revved the motor. I don't remember which way it went, but it would brighten and dim, no flickering at all, like the gas pedal was a rheostat.
Flicker
Sorrry, guess that's what I meant. It had a varying intensity, bright to dim. This is I suppose was due to the resistance range in the sender for the gauge reading, if connected correctly. This is probably why the original connections were, one with a ring terminal and screw down and the other the spade lug.
#10 (permalink) | ||
#11 (permalink) | |
If you should connect the GT's OP sender wires up backwards, here's what happens: When you turn the ignition key on, the OP gauge is at ~0 (switch closed) and the idiot light is brightest (10 ohms). When you turn the engine over to start it and the oil pressure reaches ~7psi, the gauge needle pegs (switch opens, infinite ohms) and the idiot light progressively dims as pressure builds (10-180 ohms). That said, if your OP gauge was behaving normally and then your gauge suddenly pegs the next time you turn on your ignition key, the first thing to look for is a broken "gauge" connection at the OP sender, else the internal connection to the OP sender rheostat is open. Open OP sender rheostat connection is not fixable . . . time to replace OP sender, I'm afraid.
#14 (permalink) | |
When I turn the key the pressure gaude pins I suspect there is a loose wire somewher but wher to check first Jeff |
74 vSportwagon sender
My California 74 wagon came with an angle block adaptor that allows the sender to be mounted vertically. This pretty much eliminates the problems with installation. I believe that this was necessary because of the EGR plumbing that had to go into the same area.
Im now curoius whether this 74 sender will work with my 71 GT guages. Both are two post, but the later model is a bit smaller. I havent tried to check the ohm range - just cuz I dont have a way to create 80 psi for the sender. Anyone know? |
Size doesn't matter.
As long as the thread on the sender are correct and the ohm range is the same you're in business. If the sender is the VDO sender then the ohm range is the same as the VDO gauge. The gauge will read in Bars on the GT gauge and PSI on the Sport Wagon, 1900 or Manta gauge.
Dave |
5,000 Post Club
David, it ain't necessarily so. When I was getting the oil pressure transmitter for Willit?'s new engine, the folks at VDO asked how many bars were in the oil pressure gage. It seems they have more than one transmitter that will fit, but they are for specific gages. HTH.
#20 (permalink) |
Anyone here who can help me? I've had oil pressure gauge problems from day 1 I got my car. When I give contact to the ignition everything is fine. As soon as the car starts the pointer goes all the way to the right and stays like that until I turn the engine off. I changed the sender and its still the same. I put in a a new rebuilt engine..but still have the same problem. I used the old oil pump and casing which makes me believe I either have too much pressure(unlikely when it idles) or the wiring is somehow bad. Any suggestions?
