Old 11-06-2006   #1 (permalink)
Tbags32
tbags32
Unanswered: Under hood rubber weather strip question
Hello,
I am having a problem with the rubber weather strip that goes across the car from driver side to passenger side, just above the fire wall, and behind the hood latches. I purchased a new strip from OGTS because the old one was missing.
MY PROBLEM: With the rubber strip installed the hood will not close and latch shut no mater how I push down on the hood, it will not latch. So if I remove the rubber strip, the hood will close and latch however the hood is low and hits the windshield wipers. So I prefer to have the rubber installed and have the hood shut correctly. Has anyone had any experience with this and is their an adjustment to make this work correctly.
Thanks for the help
Tom
tbags32 is offline
Old 11-06-2006   #2 (permalink)
spdkilz02's Avatar
spdkilz02
ya i had the same problem as well...i just had to trim the strip to make it a little shorter, and then the hood closed perfectly fine...
Adam
spdkilz02 is offline
Old 11-06-2006   #3 (permalink)
Tbags32
tbags32
Hood strip
How did you trim it, from the bottom that attaches it to the car body, or the top that mates with the hood?????
tbags32 is offline
Old 11-06-2006   #4 (permalink)
bq97
Did you try adjusting the latch bar?
bq97 is offline
Old 11-06-2006   #5 (permalink)
Tbags32
tbags32
No I did not try adjusting the latch bar. Is there an adjustment for it and where is it located????
tbags32 is offline
Old 11-06-2006   #6 (permalink)
guyopel's Avatar
At the firewall Are two brackets with 10mm bolts , just loosen and raise bracket up ( adjust both sides ) .HTH
Guyopel
---Thomas Edison
guyopel is online now
Old 11-06-2006   #7 (permalink)
Tbags32
tbags32
Thanks Guyopel. That sounds like the correct way to fix my problem. I'll try it tonight.....
Thanks again
Tom
tbags32 is offline
Old 11-06-2006   #8 (permalink)
spdkilz02's Avatar
spdkilz02
the problem i had with trying to adjust the latch bar was the fact that once i got it to be somewhat ok, the hood still stuck up higher then it should...back when i had this problem, i called ogts and they just told me to trim it from the top and that made it perfect.
Adam
Old 11-06-2006   #9 (permalink)
Tbags32
tbags32
It sounds like both operations (adjusting and triming) may have to be performed. Thanks for the replies.....
Tom
tbags32 is offline
Old 11-06-2006   #10 (permalink)
bosco's Avatar
bosco
Luckily I installed mine when it was about 115 degrees outside (only about 110 in the garage!!) so it sorta molded to the shape it needed to......no adjustment necessary.
1973 Opel GT
1977 Datsun 280Z
Previously:
1971 Opel GT
1973 Opel Manta
bosco is offline
