Old 04-07-2007   #1 (permalink)
scodari is on a distinguished road
Unanswered: Removing Rear Bumpers
OK Guys, I hope you can help me figure this one out......I am hoping there is some trick to this especially since we have already spent hours on this without success. We are trying to remove the rear bumpers off of our parts car; we were able to get the two top bolts off, but we can't get the last bolt on the lower part of the bumperette off. We've tried from inside the car and outside the car (through the taillights). We've tried regular sockets, deep sockets, swivel sockets, extensions, once again without success. Please enlighten me as to the best way to get to this last bolt? Also, does anyone know what size it is.
Thanks
scodari is offline
Old 04-07-2007   #2 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
If I'm not mistaken, it is a 13mm bolt. It should come off from outside, not inside the tail light area. The bolt is through the bottom of the bumperette.
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 04-07-2007   #3 (permalink)
UngerDog
ungermm's Avatar
Yes, from the outside, in fact, the nut on the inside is welded to a bracket, so, you only need to use a socket on the outside to get the bolt out.
ungermm is offline
Old 04-07-2007   #4 (permalink)
www.opelgtworld.de
opelgtworld's Avatar
opelgtworld
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)"
opelgtworld is offline
Old 04-07-2007   #5 (permalink)
Which is often the problem, as the bolt seizes inside the nut, and the nut tears loose of the retaining piece (just a strip of sheet metal) and then both happily rotate without the bolt loosening from the nut. So then you reach in through the tail-light holes with the skinniest arms in the household (10 year old daughter works) or remove the entire spare tire shelf ( )and grab hold of the nut with a pair of vice-grips. THEN either the bolt loosens, or it breaks.
Old 04-07-2007   #6 (permalink)
There are none so blind as those that will not see.....I never thought to look under the bumperette....duhhhh! Thanks all....it took me about 5 minutes to get them both off!
_________________________________
1969 Opel GT
1970 Opel GT
1987 Fiat/Bertone X1/9
1988 Taurus
1996 C280
1998 SLK 230
2003 Aztec
scodari is offline
Old 04-08-2007   #7 (permalink)
www.opelgtworld.de
opelgtworld
A picture says more than thousand words...
