Old 04-17-2007   #1 (permalink)
Ricky Slade is on a distinguished road
Unanswered: GT Stock Body Heights
I have looked and not found information about the original body heights of the GT. Does anyone know for sure what an accurate measurement may be. I would be happy with the height from the ground to the bottom of the rocker at the jacking locations. Other good points might be the height from the ground up to the bottom of the wheel well openings at both the front and back centerline locations. Hopefully someone may know. The original stance or the correct heights would be very helpful. I especially do not want to be overheight with my project. Under is o.k. but not over. RACECAR SPELLED BACKWARDS SPELLS RACECAR.
Ricky Slade is offline
Old 04-17-2007   #2 (permalink)
1971 OPEL GT 1.9L 4-speed
gtmaxx's Avatar
gtmaxx is on a distinguished road
1971 Opel Gt Height
GT-Over-All Height (at Curb weight)
MODEL 31 (55.1)
MODEL 36 (55.1)
MODEL 39 (58.8)-Tallest
MODEL 51 (54.8)
MODEL 53 (52.3)
MODEL 54 (55.1)
MODEL 57 (53.2)
MODEL 57R (53.1)
MODEL 77 (48.2)-Shortest My 1971 Opel GT yahhhh...I got these out of my Manual so they're Accurate. Hope this helps you!....Maxx
1971 Opel Gt 1.9L 4-Speed Hugger Orange
gtmaxx is offline
Old 04-18-2007   #3 (permalink)
GT Body Heights
Overall height, I suppose would be a vertical measurement to some high point on the roof panel. Thanks for the info. I also guess that all GT's fall in the model 77 of forty eight inches tall. I knew someone would have some info. Thanks
Old 04-18-2007   #4 (permalink)
Yep!
That 48.2" measurement is to the highest point on the roof and is for all GTs 1969-73 in Factory configuration.
Old 04-18-2007   #5 (permalink)
Idiot with a GT
spamseptictank's Avatar
spamseptictank
Does anyone know what the distance between the ground and the bottom of the rocker panel (ASSuming the ground and rockers are level front to rear)? I'm trying to get a good idea of ride height and ground clearance. Thanks.
Dave
The difference between your butt and your soul is that God only has to save your soul once. - David Zielinski
spamseptictank is offline
Old 04-19-2007   #6 (permalink)
What are all those model numbers about, Maxx? I've never heard of them before.
How low can you go, Ricky? The lower the better, right? Did you see the Mustang in the latest Hot Rod Mag, the incredible silver and blue '67 fastback? Lowered by moving the rockers and floor up four inches... Wow. This is a great example of the new fad in ride height.
I think mine is pretty low. It just passes tech inspection, which is a 3"x3" piece of square tubing 8" long with a handle on it, the inspector shoves it around under the car, if it hits on anything the car is too low. I could bring the front end down a tad bit more, but other than that it would be hard to get any lower.
The stock rear wheel tubs have a lot of room as long as the tires aren't very wide. Today the rage is tall wheels and short tires, on a GT they can be skinny, too, since the horsepower and weight are pretty minimal. I'd like to see a GT done this way, it would look great.
jeff denton is offline
Old 04-19-2007   #7 (permalink)
Jeff, those are simply the model designation numbers for North American-spec Opels. Example: Model 57 is a Manta.
Old 04-19-2007   #8 (permalink)
Model #s
MODEL 31 (55.1) - Kadett 2 Door Sedan
MODEL 36 (55.1) - Kadett 4 Door Sedan
MODEL 39 (58.8) - Kadett 2 Door Wagon
MODEL 51 (54.8) - 1900 ("Manta") 2 Door Sedan
MODEL 53 (52.3) - 1900 ("Manta") 4 Door Sedan
MODEL 54 (55.1) - 1900 ("Manta") 2 Door Wagon
MODEL 57 (53.2) - 1900 ("Manta") 2 Door Sports Coupe'
MODEL 57R (53.1) - GM ("Manta") Rallye Coupe'
MODEL 77 (48.2) - GT 1971-73
The two digit Model Numbers are stamped on the VIN plates at the begining of the VIN number.
HTH, Jeff
Old 04-19-2007   #9 (permalink)
72redopelgt
dayresjr's Avatar
dayresjr is on a distinguished road
model #s
And there is model 79 which is the european spec GT. Which I found is what mine is.
dayresjr is offline
Old 04-19-2007   #10 (permalink)
GT Body Heights
The Nissan 350 zx has about four inches ground clearance at the lowest point. I think that is about as low as I would want to be. I just wanted some stock rocker heights front and back to try and understand the stance of the original car. I also have a frame under my car to contend with. Yep thats right, twin 2X4 steel rails. Just hoping the car can be positioned at original height or lower. Hey Jeff, yeah BTW my wheels are 17 inch torque thrust five spoke old tyme Cobra style. I have managed to keep all the rubber under the fender.
Old 04-20-2007   #11 (permalink)
I can't wait to see your car, Ricky. I'm starting to really like the modern look, you know, the huge wheels and tiny tires within the fenders. It just took me a while to get used to it!
