Unanswered: WIDE Contacts
milling work and came up with what you see in one of the pictures. The new 7 contact block will be installed in my car shortly and I will take pictures of the final install. Some of the pictures are shown with the door skin cut out of the way and the fender cut out of the way so that you can see how little room there is for this modification.
The holes are now cut into my good GT body for the 7 contact blocks. The material that the body shop used was too thin, IMO, so I was afraid the screws would strip out eventually from the pressure exerted by the 7 springs being pushed in simultaneously. I took some 1 x 3/16" steel flat home last night and made backing plates with tapped holes for the flat head screws that will hold the blocks in place. The backing plates will be held behind the sheet metal by plug welds. Pictures to follow when job is completed.
This is the finished body work to install the 7 contact block, note that all the contours that were in the door jamb for the original dome light switch are GONE.
There was a lot of body work necessary to get this done.
Very good finding!! I was actually thinking of fabricating something similar to use in my cousin's car. I didn't know they were available pre-made!
I was wondering though, do they come with some sort of a seal, to prevent water getting inside the door or the car's interior? Just don't use them for speaker connections. The headunit or amplifier will not appreciate being brutally dis/re-connected from/to the speakers each time you open/close the door. Also voltage spikes during re-connection might kill some voice coils. Unless you turn off your stereo each time a door is about to open... which will be a pain...
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 09-19-2007 at 10:37 AM. |
