Unanswered: difficulty opening door (push button)
It isn't difficult to access the locking mechanism once the door skins are removed. One bolt on the outside of the window, in to the handle one in the door jam, plus disconnecting the linkage and you can lube the living daylights out of it.
UngerDog
I don't know of any rivet points on the GT door. You have a couple areas to examine. I'll assume that pushing the button on the handle with the door open or closed is difficult. So, you will need to pull the door panel off to access the latching mechanism. There are two parts to the system. One is the handle with the button which has a nut accessible from inside the door and a bolt on the side of the door above the latch mechanism. The latch mechanism has 3 screws that hold it in place. Once you get the maneuver the 2 parts out of the door, you will be able to find out what the problem is. Then, clean and lube, Old grease plus dirt often turns to something like glue and makes things difficult to operate. Jerry
Hinges ...
The GT doors are quite long and heavy enough to wear away the hinge pins ... which allows the door to drop and load up the latches thus making them harder to operate too.
Check how worn your hinge pins are by lifting the door by the rear edge when it is open to assess the wear. Pins can be replaced - and then greasing of the pins using the zerk fittings Opel put in there will slow down any further wear. Bet you did not know they were there! - and neither did any Previous Owners ......
i guess i wasn't very clear in the original post. i have the mechanism in hand but the large toothed gear, where most of the "sticking" seems to be, is permanently fixed to the plate and i can't really get in there to clear out any residual gunk. i'm tempted to risk the wrath of the wife and run it through the dishwasher but don't know that that would be very good for the unit....
bob |
Something to Try
See how Carburettor Cleaner works - the spray can stuff or even the dip-the-whole-carb-in Kit that most Auto Supply Shops have.
If that does not work, search around and find a shop that does ultra-sonic cleaning ... but be sure to flush all the fluid out afterwards, first with hot water and then with CRC. You could even try dangling them in a 'friendly' Automotive Machinist's "hot tank" - the one they use to clean and de-rust cylinder blocks and heads etc.
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 10-31-2007 at 10:46 PM. |
'72 Opel GT (Sara)
![]() Found this definition but still wondering exactly where these are and what type of grease to use now that I know they exist... Thanks, Matt
'72 Opel GT (Fireglow Orange) Third Owner, Purchased in 1986 Current Status: Fully Restored Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars, Custom CAI, Sprint Manifold Restoration Thread Comments Thread Other Cars: '09 Pontiac G8 GT (Panther Black) '06 Pontiac Solstice (Envious Green) '99 Oldsmobile Intrigue GLS (Black Onyx) Last edited by newman27; 08-20-2008 at 06:41 PM. Reason: Added definition link... |
