Old 06-06-2009   #1 (permalink)
gtkid2 is on a distinguished road
Unanswered: dash/heater removal help
how do I get to the top screws by the windshield that hold the dash in place? also, what do I need to do to permanently remove the heater? thanks for the help!
interior work
gtkid2 is offline
Old 06-06-2009   #2 (permalink)
Real Name: Henry Padlo
badmaxdog is on a distinguished road
http://www.opelgt.com/forums/2b-seat...h-removal.html - go to this thread it should answer your question. Remember to use the search feature first to try and find answers to your questions.
badmaxdog is offline
Old 06-06-2009   #3 (permalink)
sweet thank you... so any tips on deleting the heater?
interior work
gtkid2 is offline
Old 06-06-2009   #4 (permalink)
Uber Genius
First opel 1981's Avatar
You want the entire heating system removed, or just the heater core.
For complete removal, unbolt everything and remove, then block off the fresh air input.
For the heater core only, open the heater box and remove the heater core, then reclose the heater box.
If you remove the entire heater system, fabricate something to block off the defrost ducts on the dash (assuming you will reinstall the dash) before reinstalling it to keep a fresh look.
First opel 1981 is offline
Old 06-06-2009   #5 (permalink)
I don't know why you would want to eliminate the heater? Not working? I assume when you say heater you mean the heater core? If thats the case and you want to get rid of it just run a 5/8 inch heater hose from your water pump to your thermostat housing (if you have a electric choke). This will free up the lines going to your heater core. Or you could also just cap off the thermostat housing and water pump outlets ,again,if you have a electric choke. If you have a water choke, run a hose from water pump to choke then from choke to thermostat housing.
Old 06-06-2009   #6 (permalink)
thank you very much... I'm in an attempt to save as much weight as possible. I bought a flexible extention today and I'm going to remove the dash and heater, then remembered that the intimidating slew of pipes that lead to no-where should probably be taken care of thanks! I LOVE this site
interior work
gtkid2 is offline
Old 06-08-2009   #7 (permalink)
I got the dash off, looked at the heater and decided to leave it in. if I'm going to auto-x events or any thing of the sort then I'll probably be getting up/leaving early in the day... which includes fogged-up windows so I'm leaving the heater in... but I've already made custom mounts for the guage cluster and defroster vents so I can leave the dash out that thing is heavy! and I'm finding this requires alot of thinking trying to set up a street-legal/driven performance car. it's all fun though
interior work
gtkid2 is offline
