I don't think so, but, someone may be able to prove me wrong. I have a spare cable, out of the car, I could look tonight, when I get home.
'72 Opel GT (Sara)
OK, this is going waaaaay back 20+ years when I first purchased my GT. The cable was gone completely but I had a lead on a frozen up cable at a junk yard. Someplace, I recall reading that you could drill small holes along the length of the cable and inject it with grease. I can't vouch for this working and I never did get the cable and try this. So, take that for what it is worth (maybe not much
). If it were me, I'd buy a brand new replacement from OGTS. I'm using one of those in my car and it works great!HTH Matt
Sick with Opelitus
Thanks Matt, just out of curiosity on a scale from 1 to 10 how hard should they be to turn over? I got to rotators apart cleaned lubed and reassembled light buckets back in and adjusted, they all turn very well, now I'm rewire ring the lights then I can get the cable hooked back up and see how mine work.
Pat |
'72 Opel GT (Sara)
Matt
No....its not a Buick....
Mine roll over fairly easy....The only thing is,you have to be a bit assertive and make sure that they"click in" at the end of the roll. If I could put it in terms of foot pounds... I would have to say maybe 6to8 or so. Or on a scale of 1-10 I would say a 2-3. I still need to put in a in line fuse to make them a seperate entity myself......
HTH Joe
Here's a primer on how the rotating mechanism works, and I'm sure Keith will jump in if I'm not correct. First off, the first and last tooth on the sector gear is not full length, it looks like it is worn down, but it's supposed to be that way. It has a purpose. The rotating mass is what locks the buckets open and closed, the smaller teeth on the sector allow the buckets to keep rotating past the teeth and impact the overcenter locking jaws in both positions. There is a fairly stiff spring on the jaws that needs to be overcome to lock the arm in the jaws. To unlock the jaws, to rotate back, the first movement of the sector, before the teeth engage the rotater, unlocks the jaws which allows the buckets to spin back to the opposite locking position. Here's the reason most of the spring arms break on the mechanism. There are supposed to be three split roll pins in the center hub of the mechanism. These pins take up the impact forces of the rotating mass. The three bolts that break or come loose allow the spring arms to eventually eat through the bolts and they break. A preventative measure would be to check these bolts and pins periodically, to be sure the pins ar fully engaged in the arms and the bolts are tight. HTH.
