Unanswered: Headlight Covers - Two Holes???
I'm assuming they may be for water drainage (at least that makes some sense for the top hole) but that doesn't seem to fit for the hole on the side. When in the closed position, there really shouldn't be much water getting into the lamp housing anyway (but this is the only time the "center" hole would act as a drain). And with the lamps in the ON position, this would be when most of the water would be getting into the housings and the holes wouldn't do anything 'till the lamps are rotated closed. Am I missing something simple and obvious here??? Thank you in advance, oh knowledgeable ones of EVERYTHING Opel!
Brian B - SE Michigan My "Fun Fleet": 1973 Opel GT - Completed 1976 AMC Pacer - Completed 1970 Jeepster Commando - Under Construction 1952 Willys M38 - Completed |
If you look into the holes, towards the back of the light, you'll see that the two holes line up with the headlight adjusting screws. This is so you don't have to take the covers off to adjust the up/down and right/left of the headlight.
Unfortunately, prior to my repaint I filled the holes in (just to improve the appearance) thinking that I'd simply remove the 3 screws holding the cover in place when I go to align the lights. But this explanation does make the most sense. Thanks!!
It's your car, you do with it as you wish.
Driver
Real Name: George
I like the smooth lines that you are striving for. I just got a chuckle though that you ask after they are filled and the car is painted.
![]() BTW, love the color!
Adjustments
Gene is right, they are for adjustments, they are both on the same points on both sides if I remember correctly
Keith
One reason I like these people they don't hammer you only advice, just the facts ..hope everything works out for you in your car and preceding messages tell the story
There's nothing wrong in filling in the holes, it's just that now he has to take the covers completely off. But, if it looks better to him with the holes filled in, COOL!! Looks nice!
