Unanswered: Headlight mechanism problem
#2 (permalink) | |
While your down there a shot of lube would be good also.
Headlight Alignment
First you must ensure that all bolts and clamps are tight and unbroken - particularly the three 5mm hex-head bolts that mount the bucket to the turning mechanism (they are a standard Metric thread so can be replaced with M5 X 0.8mm pitch Allen head capscrews if required. The cap screws are both tougher and stronger than the originals and can be done up tighter IMHO).
Make sure that each bucket is correctly located in the guards - even gap all around both up and down and level with the opening in the guards. If not the adjust each bucket both at the forward pivot point and the rear bracket. This is easier if you disconnect the cable from the tie bar and undo the clamp bolt that holds the two parts of the tie bar together (see illustrations from FMS below) Manually lock both head lights up. Re-clamp the tie bars together and adjust the nuts that anchor the cable to the body sheet metal above the radiator till the end slips on to the tie bar pin. You should be pretty close to right by now - though a bit more too and froing on adjustment may be needed to get the correct positioning and locking both up and down. PS: It only took 3 people 3 days to get mine back in and correctly adjusted after removal for painting! So it is not a quick job ....
'72 Opel GT (Sara)
Headlight Saga
Here's the update: I had to get a good used rotating mechanism from Gil from the driver's side, the old one was bent. The problem is now this: After numerous adjustments to both the cable and the bolts, the lever on the mechanism does not travel far enough to hit the microswitch to turn the dash indicator off in the down position. The lights will work fine in the up position, the lock and the dash indicator light goes off, but it wont in the down position. The actuator arm doesn't appear to be bent, but it almost has to be the reason for this. Does this sound correct? I'm not actually doing the work, but the guy doing it has been in business for years and he has done everything he can think of. Kind of at a loss here. Would replacing the actuary arm be possible? Is there something we're missing? Please help!
![]() Don |
According to my DESTEC schematic, the microswitch in the driver's side bucket that has the Red/Black and Brown/Black wires is the one that turns on the indicator light at all positions other than down and locked. You can bend the microswitch actuating arm to insure the indicator light does indeed go off when the headlights are closed and locked. HTH
| Tags |
| head lights, headlites |
