Old 09-19-2009   #1 (permalink)
Dale .D's Avatar
Answered: head lights out !!
Going to work at 5 am, dark country road. All head lights shut down. Almost SH! myself. Got back home on my emergency flashers. If I blinked just right I could barely see. All other lights are fine including the dash thingy saying my lights are on. The whole light system was rebuilt a couple of years ago & have been perfect. The high beam switch doesn't click now on the steering wheel!! No high or low beam. Hope the problem isn't in the column. Been reading about fusible links off the starter & starter relays. Checked out visible wiring & grounds & seem fine. What should I do next? I like pictures. Also my low beams have alway been super low. Not sure if thats a factor. Which one is the relay switch behind where the fuses are? Thanks for all advise.
Dale .D is offline
Most Helpful Answer - Posted by sawdust
Originally Posted by Dale .D View Post
Where is this micro switch?
rotator - Opel Photo Gallery
you have two rotators
Old 09-19-2009   #2 (permalink)
had exactly the same problem and wound up leaving the car in a parking lot while i got a ride home. finally tracked it down to the microswitch in the rotating mechanism which crapped out for whatever reason. i was able to jump across the headlight relay to bypass the microswitch so i got lights back. try bypassing the microswitch and see if the lights come on. also, check the grounds! very common problem. basically you need to trace along the headlight circuit and find out where the interruption is.
bob
rsefczek is offline
Old 09-19-2009   #3 (permalink)
Dale .D's Avatar
Originally Posted by rsefczek View Post
had exactly the same problem and wound uleaving the car in a parking lot while i got a ride home. finally tracked it down to the microswitch in the rotating mechanism which crapped out for whatever reason. i was able to jump across the headlight relay to bypass the microswitch so i got lights back. try bypassing the microswitch and see if the lights come on. also, check the grounds! very common problem. basically you need to trace along the headlight circuit and find out where the interruption is.
bob
Dale .D is offline
Old 09-19-2009   #4 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
Projekt 2009 - Der OPEL GT
Other Cars:
2006 Solstice (Aggressive)
2010 Fusion Hybrid (White)
LINK to my picture Albums
sawdust is offline
Old 09-19-2009   #5 (permalink)
the microswitch (es) are located on the back of the rotator mechanism and are a bugger to get at, that's why bypassing them to see if they are the problem is better than just going after them
bob
rsefczek is offline
Old 09-19-2009   #6 (permalink)
Check the ground over by the brake booster. I think thats the grounding
point for both headlamps.
Old 09-19-2009   #7 (permalink)
Dale .D's Avatar
Great picture. I see now. Is the fact that the clicker not working after the lights went out point to the problem? Don't want to start taking things apart until I know the problem is probably there. Is the main relay switch one of the prug-in units by the fuses?
Last edited by kwilford; 09-19-2009 at 11:56 PM. Reason: C'mon Dale, a bit of effort is spelling and such wouldn't KILL you :)
Dale .D is offline
Old 09-19-2009   #8 (permalink)
Gordy's Avatar
If the tail lights and dash lights come on when you flip the lights then the micro switch is doing it's thing and thus the tail lights etc work. If that switch were bad there would be no lights at all.
If nothing happens the micro switch is bad.
If the tail lights and side markers DO come on, then the relays down in the fuse block are bad and they aren't making the headlights come on. Change the relays in the fuse block.
Gordy is offline
Old 09-19-2009   #9 (permalink)
Dale .D's Avatar
Now we are making some headway. Not really electrically inclined so really glad for the help. All lights work as normal except the headlights. Is there a main relay switch & a high & low relay switch? Both high & low beam disappeared? As well the clicking on the column arm went at the same time doesn't work as well. That must point to something. Doing this process of elimination is great with you folks in the know. Thanks! So far it seems that we have eliminated the micro switch. Are there any pictures out there showing the location of the main or hi & low relay switches?
Dale .D is offline
Old 09-19-2009   #10 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
fuse panel
Other Cars:
sawdust is offline
Old 09-19-2009   #11 (permalink)
Gordy's Avatar
Because the relays are shot there will be no "click" as you pull back on the turn signal indicator lever. I had my dim relay go out once and by holding the lever back it kept the high beams engaged so at least I could drive home.
Gordy is offline
Old 09-19-2009   #12 (permalink)
Headlight circuit diagnosis information available at link.
http://www.opelclub.com/GTHeadlightsAugust2004.pdf
Anonymous D is offline
Old 09-20-2009   #13 (permalink)
Step 5 just how do you check the ground?
And you could have power at "A" and "B" with very little current flow.
Old 09-20-2009   #14 (permalink)
Dale .D's Avatar
Good article.Are the 2 units there the high & low beam relay circuits?
Dale .D is offline
Old 09-20-2009   #15 (permalink)
Dale .D's Avatar
So at this point would it be prudent to replace these 2 relays from OGTS & see if it does the trick?
Dale .D is offline
Old 09-20-2009   #16 (permalink)
Dale, to start replacing parts to see if they are the problem is a bit problematic. And expensive. My advice is to systematically trouble shoot the headlight circuitry. It's not very difficult, although some folks talk as if its rocket science. To start, make sure you have the Factory Service Manual headlight schematic at hand. I like the circuit-specific schematic, such as Figure 120-102 in the 1971 and 1972 FSM's rather than the big colour all-circuit schematic. Start by following the logic of the headlights in the schematic so you see how they work. Then do some simple tests. The description in the OMC article is pretty good, so also refer to that while you check:
1) Is there power to terminals 30/51? That is the main source of power for all the headlights, right off the main fuse box bus (NO FUSE!). If you have parking and dash lights, you must have power to 30/51, so move on.
2) headlights open, ignition on: Is there power to terminals 85 (which is sourced from the ignition, via the micro-switch) on the headlamp relay?
3) Again, that probably isn't the problem, since you have parking and dash lights, so I would expect that the headlamp relay IS working, and the problem is "downstream" and confined to the headlight circuit. For the sake of others doing trouble shooting, if no power to 85, then work your way back through the schematic, by checking if the headlamp relay switch (the famous micro-switch) is getting power (comes from a black wire on the fuse box, refer to the schematic). If so, and no power at the #85 terminal, then the micro-switch isn't working. This is NOT as common as folks seem to think, at least by the number of GT's that have had the micro-switches bypassed by some abomination of PO wiring. Another way to check is to simply use a wire lead and PUT power directly to #85. If the headlights come on (or you now get power to the relay output, terminals #87), then either the micro-switch is malfunctioning, or there is a problem with the wiring.
4) if the relay IS getting power to #85, is there power at the #87 terminals? If not, the relay is malfunctioning. Either try repairing it (another thread talks about that somewhere here, I've done it, not very difficult) or buy a replacement. If yes, then follow the power to the next location, which is the dimmer relay.
5) ignition on, headlights open, power at #87 on the headlight relay: Is there power to #56 on the dimmer relay? Bloody well better be, as the wire is only about two inches long!! But check if there is power at either #56a (high beam) or 56b (low beam). Should be at one or the other. If neither, then the dimmer relay is malfunctioning (either repair or replace).
6) You're on the home stretch. If you have power to the dimmer output terminals but still no headlights, you have a problem with either the wiring to the headlights (and GT's are more than famous for that) or a bad ground to the headlights (also common, check the multi-wire ground as they attach to the body with a screw on the driver's side inner fender just ahead of the radiator brace) or maybe even two burned out headlights (not bloody likely if you have NEITHER low nor high beams).
Old 09-20-2009   #17 (permalink)
Dale .D's Avatar
Great info as always.I'll give it a try.Thanks
Dale .D is offline
Old 09-20-2009   #18 (permalink)
Dale .D's Avatar
Well there's power at # 85 but not at # 87.So it looks like that Relay is shot.I'll order that relay & for the heck of it take it apart & See if I can see the problem. Now for a cruise on the new paved rd between Lake Cowichan & Port renfrew.Cheers & Thanks a bunch.If your ever on the Island Keith!
Dale .D is offline
Old 09-20-2009   #19 (permalink)
Hmm, are you SURE that there is power to #85 (which means that the headlight micro-switch relay is working), AND power to #30/51 (the main headlamp power feed from the fusebox bus) and yet no power at #87 (which should come on when the relay is "energized")?
And you have parking and dash lights when you are checking?
Do you have the parking light rocker switch on then, or off?
What happens if you jumper a lead from #30/51 over to #87? The headlights should come, as that bypasses the relay.
Old 09-20-2009   #20 (permalink)
Dale .D's Avatar
Headlights were up,Ignition on but the parking light rocker was not on.I'll do it again & see what happens with the rocker on.
Dale .D is offline
Old 09-20-2009   #21 (permalink)
West Coast GT's Avatar
West Coast GT
I'm not suggesting you resort to the "replace parts til you find the problem" method, but I do recommend replacing both relays. These old electro-mechanical relays are prone to oxidation and weak, or loss of, headlamp beams.
So while you're trouble-shooting your headlamp system, and before you forget how it works, replace the relays. You'll be doing it someday anyway, so just do it now and have confidence in the system.
But I would find & fix the problem before swapping the relays so you don't;
1. damage the new parts,
2. end up with a compound problem where before you only had a simple (single) issue.
I installed both replacement relays from OGTS two years ago and found it was painless. They provide excellent instruction.
West Coast GT is offline
Old 09-20-2009   #22 (permalink)
Dale .D's Avatar
Update you are right.When the rocker driving light switch is on with the rest of them # 87 is live. I jumped # 30/51 to 87 & the lights came on. Next with all headlights on ignition on & rocker switch on I tested #56 & nothing. Also tested #56a & 56b & nothing.Noticed on the laminated destec it talks of a fusible link at the starter thats linked to 56 I think. Found it ( thick black wire with yellow 3 inches long) at started Tested that & it's OK .Not sure where all this leads me?you said # 56 should be live .Followed it over to the 7 pronged relay & nothing either???
Dale .D is offline
Old 09-21-2009   #23 (permalink)
OK, you had mentioned earlier that "...All lights work as normal except the headlights..." Which I took to mean that when the rocker switch was off, and with the headlights up and ignition on, that the parking and dash lights were lit. I presume that the parking and dash lights only actually came on with the rocker switch, which is independent of the main relay. It is possible that the relay could actually partially function, and that only the headlight contacts are not conducting. There are actually four independent contacts inside the relay, and four corresponding terminals outside, which prevents the parking and dash light switch from powering the headlights).
When you check for power at 87, as I asked above, you actually need to check all four terminals, WITH the rocker switch off. There is one terminal each for:
1) licence light and dash lights
2) right side marker lamps
3) left side marker lamps
4) headlamps (and white dash indicator lamp)
As for power at the 56, 56a and 56b terminals (which respectively are the feed into the high beam relay, the high beam and low beam terminals), you could only have power there WHEN you have power to the output of the main relay (the #87 terminal that is directly connected to the headlights, and only when the rocker switch is off) which in turn powers the high beam relay.
So if that is all true, and now that you have confirmed that the remainder of the headlight circuitry is intact by doing the "30/51 to 87" jumper, I think that your main headlamp relay IS faulty. Nice to know before you spend the money.
Since the relay isn't working anyway, why not take an hour and pop the case off, and see if you can figure out what is wrong inside. In simple terms, if you put power to the 85 terminal and ground the 86 terminal, the relay solenoid electro-magnet should pull the contacts closed (you should hear a click, or actually see the movement if the case is open). It appears that isn't happening, possibly due to either the electro-magnet being damaged, or more typically, because the contact arm gets gummed up and won't move the contacts together. Not much you can do if it is the magnet, but cleaning the movement and the contact points might get it working again.
And frankly, while a mechanical relay isn't as inherently trouble free as a solid state relay, they are pretty darn reliable, given their age.
Old 09-21-2009   #24 (permalink)
1971 GT
CDN OpelNut's Avatar
CDN OpelNut
What gives?
OK - I really apologize for this post in advance and hate to broach this topic again, but I thought these types of posts were now not allowed, after much discussion.
Particularly in the thread that contains this post:
http://www.opelgt.com/forums/197968-post10.html
(I realize it's the same poster)
Are we really to assume that after much complaining, only a select few get to violate this "policy".
There have been times where I have had information that may have been helpful that I refrained from posting because of this. I really don't get why someone would complain so loudly about something and then proceed to do it......
Again - sorry, but is this allowed on the forums or not?
CDN OpelNut is offline
Old 09-21-2009   #25 (permalink)
"Articles, photographs, drawings, technical tips, and other materials appearing in the Blitz may not be reproduced without the expressed, written permission of the OMC."
If one of the OMC members wants to give away info by posting articles on this site...I say cool...but It does leave our members being tight lipped with releasing info.
This subject has been hammered to near death.
Just my opinion with no harm intended to anyone.
