Unanswered:
#2 (permalink) | |
M5 Headlight Rotator Bolts
I have split these posts into it's own thread. HTH
SAE #10-32 thread is IDENTICAL to the M5 thread
Almost forgot the most important fact. A #10-32 thread is IDENTICAL to the M5 thread. So you can also use SAE Grade 8 #10-32 socket head cap screws (or even just plain hex-head bolts) . HTH
Gaaah!
#10-32 threads have 32 threads per inch or a pich equivalent to 0.79375mm
M5 X 0.8 threads have a pitch of 0.8mm - CLOSE to the same. They fit because the thread angle is the same - 60 degrees and the diameter is also very close to the same. But they ain't "the same"! Use M5 X 0.8 cap screws - the holes ARE tapped M5 (DIN spec probably - GTs being German). A tiny dab of "Super Nut Locker" Loctite (TM) helps stop them backing out at a later stage.
Keith, et.al., After long pondering about why the bolts break or are sheared off, and looking at my mechanism, I came to the conclusion that maybe the 3 roll pins are not engaging the spring plates, thereby causing the plates to shift radially and eventually cut into the bolts. Looking at it from an engineering point of view, it appears the bolts only hold the spring plates to the hub and the roll pins are designed to make the whole assembly rotate and take up the stress of the assembly stopping and starting. The pins are definately easier to replace than broken bolts. It could be the pins are driven too far into the hub to completely engage all the spring plates. Whatcha think?
No Access
Since I'm going down this road what happens is the bolts have a tendency to back out over time and put the stress on them without the aid of the roll pins. At that point or when one of the 3 comes completely out it starts shearing things. In the winter with the rotator cold it has a tendency to take out gear teeth but still seem to work. This puts an added strain on the little bolts and roll pins until something gives or works loose. I've got several here to repair and had a good chance to find what made them fail.
