Old 11-12-2005   #1 (permalink)
73OpelMan is on a distinguished road
Unanswered: Mechanical light Prob!
Hello,
Well I am taking my whole light system out to be all re done and new parts put in but the problem is I CANNOT get the dash piece that covers the mechanical lever for the lights out. If anyone can help me please post!
Thanks
Spencer
73OpelMan is offline
Old 11-12-2005   #2 (permalink)
Spencer, just looked at mine, out of the car. There are four spring clips, they go into holes in the metal structure. One in each rear corner and one each just forward and outboard of the shifter hole. The forward edge of the panel slips under the instrument panel. HTH.
Old 11-12-2005   #3 (permalink)
Dash piece? Do you mean the front console? Have you removed the lever handle? There is a small slotted set screw in the side. Then remove the ash-tray base (two screws) and GENTLY pry up the console.
Or do you mean something else?
Old 11-12-2005   #4 (permalink)
I am talking about the piece where the automatic shifter is located. Also Will I have to have this up on a lift to do this?
Old 11-12-2005   #5 (permalink)
Nope, you can do this sitting inside the car. Just do as Keith indicated. HTH.
Old 11-12-2005   #6 (permalink)
I haven't worked on many GT automatics, but I think they just have an extra trim piece that covers the round hole where the stick shift usually is. Doesn't it just pop off? Then you remove the front console as described above. To remove the headlight lever, there are two bolts on top of the tunnel (under the front console) and one along the side (under the carpet and foam padding). But you have to get under the car to disconnect the linkage from the cable.
Why are you removing the lever?
Old 11-12-2005   #7 (permalink)
I am removing the lever because it is a pain in the butt because I have to use two hands and a foot just to get the lights to turn over and lock and come on. So I need to get all that out to make sure there is no coins or anything stuck.
And to answer your other question the thing wont just pop off. Thats what I thought it would do, but I have resorted to literraly pulling as hard as I can and it still would not pop off.
Old 11-12-2005   #8 (permalink)
Spencer, did you disconnect the cable from the actuating arms yet, just to be sure it's the cable and not the rotaters that are sluggish? You may not have to pull the console cover off if it's not the cable that's binding.
Old 11-12-2005   #9 (permalink)
Yes Ive done everything else and everything else is greesed up cables are checked and its still being a pain.
I did get the console off, I just used a crap load of force and slightly bent one edge but thats ok. Now They console wont come off cause the lever is in the way for the lights....How the heck does that come off?
I tok out a TINY screw that was on the right side of the lever but that did nothing so I put it back in lol...any other advice?
Old 11-12-2005   #10 (permalink)
asdasc's Avatar
Take the tiny screw back out, you were on the right track.
Then gently pry it off. I am pretty sure the only thing holding the plastic handle on is the set screw in the drivers side of the handle.
Steve
asdasc is offline
Old 11-12-2005   #11 (permalink)
No Access
I've heard of 2 similar experiences lately. One in which it had been glued on and finally cut off. The other was heated a bit and came off fairly easy afterward. Just in case it doesn't go well, I do believe OGTS sells new ones.
nobody is offline
Old 11-12-2005   #12 (permalink)
Rings a Bell ...
The handle on the lever of my GT's headlight lever had TWO small screws in it - one on top of the other. Obviously the screw had worked loose at some time and would not stay tight so a second screw had been used to lock the first. Worth checking! The original has a slot in it BTW - it is not an allen grub screw.
Copyright İ 2000-2009
Old 11-12-2005   #13 (permalink)
After lubing everything did you disconnect the cable assembly from the rotating assembly up by the radiator? That is how you will be able to tell if the problem is in the cable/lever or in the rotators. You may be doing the console thing for nothing! I see that this question was asked previously, but your answer was not definitive.
Old 11-12-2005   #14 (permalink)
Well to tell you the truth I have no clue where that cable is, I know you say by the radiator but I cant not find a cable that conects to the rotators or whatever they are called.
Iam very new at this so things need to be explained in details so I know what the heck I am looking for.
THanks for the help so far guys,
Spencer
Old 11-12-2005   #15 (permalink)
No Access
With the hood open it's just under where the hood opening is in the front. There is a clip that holds the cable end on to the rods for the lights. if you take the clip off and work the cable end off you can work the cable part and the lights seperate from each other to find the problem.
nobody is offline
Old 11-12-2005   #16 (permalink)
wrangler's Avatar
Real Name: Brett
wrangler is on a distinguished road
spencer, there is a spring clip right near the hood hinges that attaches the cable to the rod that rotates the headlights. if you disconnect the cable and it moves freely, then like others said, your problem is not inside the cab.
Brett
ALso, do you have a service manual? If not I have one for a 71 that would help you alot in most areas. All you have to do is come and get it!
there is a thread under "headlight cable" by rangerrick with some pics if you still are unsure.
Oops... Nobody beat me to it! lol
wrangler is offline
Old 11-12-2005   #17 (permalink)
Here you go!
Old 11-12-2005   #18 (permalink)
Ok thanks a bunch for the pictures guys that help A BUNCH!!! Also thanks for the call wrangler, that helped a bunch too!
Now I got the cable thing off and it slides somewhat ok with alittle risistance. Is there sposed to be ANY resistence or should it slide in and out very easily.
Also the cable for the lights that switches back and forth has no problem sliding back and forth, and no resistance so I am thinking it is the cable I had a *Beep* hard time getting off.
One more question, any specific greese I should use? AND where do I put it..on the pole? or somewhere else?
Old 11-12-2005   #19 (permalink)
rangerrick is on a distinguished road
Look again at my pic. & lube hose on end.
73 GT. I used a rubber hose attached to the end of the cable, filled it with a thin penetrating type oil (NOT DIDLY D 40) (WD40) gets gummy after a while and can make things worse!!! Once you got the oil in the hose, slowly hit it with some shop air to help push it down the legnth of the cable. If you remove the acuators behind the hedalmp buckets, soak them over night in kerosene as per Gil at OGTS, then lube them up well with a thin oil before reinstallation. I did this and mine work slick. I spent about 2 1/2 days on this
My headlights are now intermittent switch or relay??? I'm not sure, neat feature but a Major PITA for what it's worth!!! I dont care for there engineering of how the lights come on and off, built in gaurentee you'll be driving in the dark with NO lights someday and no easy fix roadside!!!
Regards,
Rick
rangerrick is offline
Old 11-12-2005   #20 (permalink)
I would say to lube the rod that sticks out of the cable. Sounds like your rotators are OK if you can move the horizontal rod easily. What can happen is that the rod is dry and when you push on the cable it deforms a little bit and causes a lot of friction/resistance. There should also be a spring in the same area which helps when closing. You should still get to the rotators and at the very least squirt some good long lasting lube into them.
Old 11-13-2005   #21 (permalink)
Good news!!!
The entire project I started today on repairing the mechanical lever is finally finished after ten hours of nothing but car work today. (I will list what else I did in that ten hours). But thanks to all of your help the lights are pushed on and off with one hand finally and is quite easy to do so.
Also I got plenty of other things done today!
1. Lights (Ofcourse)
2. Fuel system (Tank checked over, new fuel lines, new fuel filter.)
3. New windshield wipers
4. New inginition coil (YOu guys helped me on that one too!)
5. New front and back brakes (That took a good two hours, rotors and pads)
6. Seatbelts were repaired.
7. New spark plugs and, distributor, and rotor for the distributer.
8. Complete fluid flush and re fill (Anitfreeze, oil, transmission fluid, break fluid, washer fluid, you name it it was done.)
9. Dash lights replaced (Can finally drive at night)
Well that is the list of everything I got done and thanks to this site my two hardest project times were cut in half. THanks a bunch guys!!!
Old 11-13-2005   #22 (permalink)
asdasc's Avatar
Excellent!! That is quite a list of accomplishments for one day. The big question is, did it run when you were done!?
Just kidding, but it seems whenever I 'fix' something, it shows me something else that needs to be done. Sorry I had to bail out on you the other night, but it was about 3am and I had to hit it. It sounds like you did fine on your own!
Steve
asdasc is offline
