Which MIG Welder for Body Work?
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Which MIG Welder for Body Work?
    Senior Member My location EJprovost's Avatar
    Oct 2004
    Utah
    509
    I need advice on the right welding equipment to buy for welding on the body of a GT. I am looking at a MIG 90 AMP FLUX WIRE WELDER, 115 Volts. Any suggestions? I would like to do some minor welding here and there and after that use the equipment to weld together extra car parts for a garden sculpture. Will this equipment work?
    "Enjoy The Ride!"
    1969 GT, 1973 GT "Quazar"
    1995 Camaro Z28
    New Birthday presents for daughters:
    1970 GT, 1971 GT
    Mar 2006
    Utah
    88
    Liz...It will work..but not too well...get a MIG that is convertible from core wire (gasless) to gas wire using argon mix. The core wire works great with thicker metal, but for body panels you will find the gas works much better...Lincoln 135 MIG is a really nice setup, reasonable price, and runs on 110 volt. They usually come with the regulator but you will have to get an Argon mix tank at Welders Supply...kinda pricey for what it is though.
    Kalifornia Kid My location DennisGardiner's Avatar
    Jun 2002
    Santa Clara, CA
    550
    I will second that vote.
    Get a MIG that uses the Shielded Gas.
    I have recently upgraded from a Non-Gas Mig to a Lincoln 180c (I'm using NOS gas, recommended by my gas supply house) and the difference in weld performance is night & day.
    With the old welder, I easily burned through Opel sheet metal. To slow or 'try' and prevent this I'm crank up the air compressor to reduce the voltage in my garage so I could weld better.
    With the new welder,.... oh my!!!!! the welds are sooooo nice, it makes me look like a professional boiler maker!
    Clean, no slag, excellent penetration, no burn through, easy to start the arch, ..... just so, so so nice.
    I'll never go back to my old machine, (unless I really hate myself that day).
    Dennis:banghead:
    Opeler My location SpringGT's Avatar
    Mar 2006
    Houston, TX
    1,048
    10
    Get a MIG that uses inert gas shielding. It's much better than the flux core and will make you proud of your welds. Look at the Millermatic 140 if most of your work is auto bodywork. It is 140 amp (24 ga.- 3/16" capability), uses 110 V.,and uses gas shielding.
    It has automatic setting. You just dial in metal thickness and wire size and it gives you the proper setting, or if you want you can manually set the amps and wire feed speed. If you get a much larger amp capacity than this, you'll need a 240 volt input supply.
  7. #5
    Swansea, MA
    8,988
    Gary
    4
    I bought one of these cheapo imported TIG/ARC/Plasma cutter combo units. Have not used it extensively yet, but the plasma cutter and stick welder work well. There was a minor problem when I first fired it up but that was fixed by removing the cover and checking the internal plug connections as one was loose from shipping. TIG should work well for sheetmetal and you can weld aluminum with the AC/DC model.
    www.alt-opel.us
    @opelgary
  8. #6
    Oct 2004
    Utah
    509
    Nice suggestions! This is exactly what I need to know. Now for the Garden Sculpture: I thought I would do my own engine rebuild with a lot of sarcasm involved. I have a bunch of crazy carbs I took off the cars I bought, those are going to look real good attached to my engine creation. Will the above welding recommenations be able to weld the heavier metal in the carbs and manifolds?
    "Enjoy The Ride!"
    1995 Camaro Z28
    1970 GT, 1971 GT
  9. #7
    Member My location Dennis Texas's Avatar
    Oct 2006
    Texas
    382
    I bought one of these cheapo imported TIG/ARC/Plasma cutter combo units. Have not used it extensively yet, but the plasma cutter and stick welder work well. .
    Have you used it for cutting stainless yet if so how thick will it go and how good did it respond?
    If everything seems to be going well you have obviously overlooked something.:banghead:
  10. #8
    Swansea, MA
    8,988
    Gary
    4
    Quote Originally Posted by Dennis Texas View Post
    No stainless yet. It cut through a piece of 2" channel iron like it was butter and then made some fancy designs some sheetmetal.
    www.alt-opel.us
    @opelgary
  11. #9
    boomerang opeler My location baz's Avatar
    Jun 2002
    sunderland england
    5,581
    barry williams
    Quote Originally Posted by EJprovost View Post
    mixed metals like steel/cast iron and the alloys used in a carb will not weld together you can weld steel tabs to bolt the carbs on to it though
    Copyright © 2003-2012 barry williams
    B.O.O.B. founding member
  12. #10
    Oct 2004
    Utah
    509
    Quote Originally Posted by baz View Post
    I'm used to using a mixture of oxygen propane, however I don't think that will get hot enough. What gas or mixture should I be using to weld the steel tabs? Or will the MIG welder work?
    "Enjoy The Ride!"
    1995 Camaro Z28
    1970 GT, 1971 GT
  13. #11
    Detroit,where my home was My location 2 Fast 4 U's Avatar
    Oct 2005
    Maria Hoop, Netherlands
    2,792
    Erick Janssen
    With the mig welder I use a mixture gas of 86% Argon and 14% CO2, welds very wel with my recently bought mig welder, just see if the transformer wires are made of copper instead of aluminium, they are a bit expensiver but are a lot trust worthy. jmtcw
    Opel Ascona;
    Only built from 1970 - 1975
    Understeer: The front of the car hits the wall,
    Oversteer: The rear of the car hits the wall,
    Horsepower: How fast the car hits the wall,
    Torque: How far the car pushes the wall.
  14. #12
    Oct 2002
    Mahopac, NY
    4,036
    You can also get a 100 Amp machine made by Lincoln at your local home depot. Just make sure it is the model that comes with the gas gauges and you are all set. Mine will weld up to 1/4" material, but can be turned down for sheet metal when you use .024" wire. You need a 20amp circuit to power it, and don't use an extension cord unless it is at least 12ga and not over 25' long.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  15. #13
    Old Opeler My location GTJIM's Avatar
    Jun 2003
    New Zealand
    5,565
    Oxy-acetylene
    The oxy-propane mix is best used for cutting and heating - if you want to weld steel you need oxy and acetylene for a 'gas' torch - one with a flame.
    An electric MIG welder will weld steel tabs/screw studs very well too.
  16. #14
    Oct 2004
    Utah
    509
    Harbor Freight is having a sale right now on this type of equipment. The brand name on the equipment is "Chicago Electric". Anyone familiar with the quality of this brand?
    "Enjoy The Ride!"
    1995 Camaro Z28
    1970 GT, 1971 GT
  17. #15
    Mar 2004
    new jersey
    321
    mig
    Yes. Go with miller or Lincoln. The Lincoln equip at home depot works well for home/shop use. I have a lot of knowledge with welding and would not use much else.
  18. #16
    Moderator Site Supporter neuropel's Avatar
    May 2002
    Pottstown, PA
    2,410
    Todd Kirby
    It's the cheap, chinese-made stuff. For something like a welder, I think most people would recommend going with a quality name like Miller, Hobart, Lincoln, Century, etc.
    If you DO go with something like the Chicago Electric, try to find out if your consumables will cross over with other brands (like the tips, for example). You'll eventually be replacing various parts (stuff like wire sleeves and rollers) and it's convenient to have parts near by at home improvement stores or the like.
    For working on your car a mig welder would be excellent. For your art needs, have you considered a Henrob torch? It's cheap (like $400). It's basically an advanced oxygen/acetylene torch that will allow you to weld steel, stainless, aluminum, and will even allow you to repair cast iron. It will also allow you to cut up to 1 inch thick steel. It's a little cumbersome to use at first but with practice it will allow you to make some really nice welds that approach that of a tig weld. For SMALL sheet metal jobs it's great because the heat control helps keep down warpage and your weld remains malleable (not brittle like a mig weld). It welds like a tig welder and uses tig rod - so it's slow, but it can be equally strong. One other big plus is that it is portable.
    Paddle faster...I hear banjo music!
    ________________
    1972 GT 2.4L
    1974 Manta GT/E 2.0 LHU
    1973 Manta Rallye 2.5L
    1967 Kadett L Rallye 1.1L
  19. #17
    Oct 2005
    Acworth, GA
    3,088
    juan P. Blanco PH.D.
    We use a different approach when it comes to sheet metal. If you do some research on a company called "eastwood", there is an attachement for a stick welder which allows you to weld sheet metal using thin rods. We use this all of the time and the results are excellent.
    Not bad for a $79 price tag!!
    For all other items we use the standard Lincoln gas wire feed unit which can do the rest of the work quite nicely.
    www.edcatl.com
    Home of the S-ECU
  20. #18
    Opeler My location Gary Sullivan's Avatar
    Staten Island, NY
    228
    HTR Tig?
    Anyone had any good or bad experience with the HTR Tig? They are not as pricy as the Millers & Lincolns, but I haven't heard from anyone whether or not they have used them and liked them?
    Gary
    NYAsconaGuy
  21. #19
    Kick a little asphalt My location MantAscona's Avatar
    Plumsteadville, Pennsylvania
    1,452
    Duane
    Hi Gary,
    I'm guessing you mean the HTP Invertig 201. I just bought one a couple of weeks ago. I'll let you know when I begin using it.
    Duane
  22. #20
    May 2002
    Pottstown, PA
    2,410
    Todd Kirby
    Those look like really nice units. Plus, they apparently deliver 200 welding amps using only a 30 amp 220 volt single-phase line in your shop! Can't do that with the comparable Lincoln or Miller units. Cool Duane! So let me know when you're able to lay a sanitary weld in stainless steel - I have a brewery half built. The payoffs will be worth it!
    Todd
    ________________
    1972 GT 2.4L
    1. Cost of body work
      By opelgt73 in forum 2D - Body Repairs and Modifications
      Last Post: 05-12-2006, 02:25 AM
    2. Paint and Body work DISASTER! (long)
      By husker in forum General Discussions
      Last Post: 03-05-2005, 09:20 PM
    3. Mig welder
      Last Post: 11-07-2003, 01:51 PM
    4. Wire Feed Welder versus MIG Welder
      By greensmurf20 in forum 2D - Body Repairs and Modifications
      Last Post: 05-20-2003, 05:16 PM
    5. Newbie Body Repair
      Last Post: 01-22-2003, 10:36 AM
