Old 12-10-2008   #1 (permalink)
yellowbeard's Avatar
yellowbeard is on a distinguished road
Answered: Hood Adjustment
Hello guys, How do I adjust my hood? I have started my bodywork and the front of by hood is a little lower than the nose of the car. Maybe 1/2 in. Can I put shims between the hinges and hood to raise the front or is there another way to do this. Thanks Joe
yellowbeard is offline
Most Helpful Answer - Posted by kwilford
I agree that the first thing to look for is a broken hinge mount, which is simply the vertical sheet metal strap that runs between the headlamp buckets under the leading edge of the hood opening. Here are some photos of what they look like, upside down (as I had the body inverted on a rotisserie and the belly pan removed) although they had been repaired once a long time before, by brazing the torn metal. And in case you haven't read the threads I directed you to, the hinges often seize, which in turn tears the mounting sheet metal, as it isn't very sturdy
Old 12-10-2008   #2 (permalink)
Joe;
There also may be the possibility that your hood hinge is broke. Can you supply pictures? Take some through the grill of the car, back up at the hinge.
Old 12-10-2008   #3 (permalink)
UngerDog
ungermm's Avatar
1/2 inch? I wouldn't think you have that much. There is only about 1/16 to 1/4 inch difference between the thickness of the hood and the nose shelf that the hood sits in. You can place shims or washers between the two front holes of the hood and the hood bracket to make things flush.
Jerry
ungermm is offline
Old 12-10-2008   #4 (permalink)
Dennis Texas's Avatar
most probable cause is when a hood is rusty instead of the pivot rotating the mounting strap rolls hopefully you have caught it in time before it snapped off. This is the good time to repair it if any welding is required to the body.
you can drill out between the mounting bracket and tap for a grease zerk then grease it up when you assemble. Penetrating oil works good to free it up but does not have staying power greasing will lubricate for a long while.
Dennis Texas is offline
Old 12-10-2008   #5 (permalink)
hood
as far as i can tell there is no rust in the hood, and nothing is broken.
Old 12-10-2008   #6 (permalink)
hmmm
Look carefully at the brackets where it is attached to the car body. I can't think of anything else that could make that much difference except maybe being repaired incorrectly.
Can you get a picture of that area?
Old 12-10-2008   #7 (permalink)
Joe;
Follow the hood hinges to where they tuck up under the nose, between the headlight buckets.
Old 12-10-2008   #8 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
look in this area.
on both the left and right side
Projekt 2009 - Der OPEL GT
Other Cars:
2006 Solstice (Aggressive)
2010 Fusion Hybrid (White)
LINK to my picture Albums
sawdust is offline
Old 12-11-2008   #9 (permalink)
A brief search reveals:
http://www.opelgt.com/forums/2a-body...ge-broken.html
and
http://www.opelgt.com/forums/2d-body...ge-repair.html
Old 12-13-2008   #10 (permalink)
problem
I think I found the problem. the red bracket with the rivit in it is missing on the drivers side.
Old 12-13-2008   #11 (permalink)
I don't believe that is a factory installation on the hood hinge. It appears that bracket that is pop-riveted is a PO fix. I would look at the hinge careully as you raise and lower the hood by hand to see if there is any flex at the vertical rib the hinge is attached to. There is a nut on the stud that is the large round button you see on the rear of the vertical rib, just outboard of each hood attach arm. HTH.
Old 12-13-2008   #12 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
It could be that yellowbeard did not realize that this is how I repaired my rusted out hood hinge support. Maybe this is what he will have to do to secure his hood.
Other Cars:
sawdust is offline
Old 12-14-2008   #13 (permalink)
Old 12-14-2008   #14 (permalink)
Here is a photo of the hood after the hinges are repaired, all nicely aligned. Originally, my hood front edge was about 3/8" above the front sheet metal, which was caused by the hinge seizing and tearing the metal strap. The trick is to repair the metal strap, and also to enlarge the hinge mounting holes a bit such that the bolts that mount the hinge ends can be adjusted up and down, and also a bit side to side. That aligns the hood leading edge to the opening left to right and up and down. The remaining adjustment is in the slots where the hood attaches to the hinge, which aligns the hood front to back.
The other two are of the hinge after I had repaired the mounting sheet metal. I welded an extra piece on both sides, and wrapped them both to the front and to the rear to make the mounts quite a bit stronger
Old 12-14-2008   #15 (permalink)
Here are the extra pieces I welded in, both in front and behind the original sheet metal, and both extending into the headlight bucket for strength. This was after the rough welding, before I cleaned the welds up and such. Note that the holes are a bit larger than original to allow some additional adjustment
Old 12-14-2008   #16 (permalink)
hood fix
the pic. on my post is I believe is another members car (sawdust) I think. But It show what I believe I will have to do to fix mine. thanks guys. Joe
Old 12-14-2008   #17 (permalink)
hood fix
looks like my problem, not attacted on the end.
Old 12-14-2008   #18 (permalink)
looks like my problem, not attached on the end.
That end actually looks pretty good, but the hinge bar seems to be angled down to the passenger side. What does that end look like?
Old 12-14-2008   #19 (permalink)
hinge bar
The hinge bar is not attacked to the wall of the headlight housing, it lets that end move up and down.
Old 12-14-2008   #20 (permalink)
Ah, now I see.
While you have the hinge removed, make sure that it rotates smoothly, and it is a good idea to install grease zerk fittings in the outer tube at each end (about 1 inch inboard from the ends) to ensure that the hinges don't seize in the future
