Old 01-21-2009   #1 (permalink)
Manta Owner
deanh74_2's Avatar
Real Name: Dean Hartje
deanh74_2 is on a distinguished road
Answered: Manta jack points
On the Manta I purchased last fall, the front jack points are both rotted away. Yes, Gone
The question I have is, could I eliminate the jack points? I know it isn't stock. I also know that is how you use the jack with the car. But, there are a number of other options you could use and jack on the frame. I am just wondering before I start working on the car in the spring.
And I am sorry if this was ansered before. I did not find it.
Thanks for the help,
Dean
"Taste Death, Live Life" - "HotDog" - The Movie
deanh74_2 is offline
Most Helpful Answer - Posted by RallyBob
Originally Posted by DennisGardiner View Post
Okay found it:
Sportwagon from Hell
permalinks # 56, 103 & 129
Hard-core Opel Jack point build up!
#56 shows before, 103 shows repairs and during, 129 shows almost done.
Or for more details, go to my Flickr photo site, I have most of the play-by-play steps of the jack pad rebuild photographed.
As far as whether or not you need the jack pads...you don't technically. However keep in mind they do structurally tie the rocker panel and the framerail together, making the car stronger. Leaving a void here will weaken the car. So even if you don't use the jacking points as intended, it's a good idea to tie things together with at least a piece of tubing.
HTH,
Old 01-21-2009   #2 (permalink)
Manta Maniac
Rionart's Avatar
Yes, you can eliminate the jacking points (MMT:Manta Mud Traps).
However it is worth remembering that they also tie the frame rail to the sill, so it would be wise to beef that area up rather than just using a bit of flat plate (I'm assuming the floor is ventilated if the MMT's are gone).
Bob will be able to tell you better what gauge/cross section steel to use.
HTH, Rob.
Politicians and diapers have one thing in common. They should both be changed regularly and for the same reason.
Rionart is offline
Old 01-21-2009   #3 (permalink)
wicked wagoneer
officertyo's Avatar
Real Name: Ron
officertyo is on a distinguished road
Both front jack points are missing on my car also. I also had to weld on my drivers side frame rail because it was mostly missing. I just use a floor jack and jack the car up from there. When i also use a lift at work i lift it from the frame rails. I see no need for you to put new jack points on the front. Because to me the stock jacking system is dangerous. Just use a floor jack.
officertyo is offline
Old 01-21-2009   #4 (permalink)
UFO pel abductee.
Aardvaark's Avatar
Just be sure you carry what it takes to jack the car up safely when your out on the road in case of a flat. So you don't
-Mark
'75 Manta
Aardvaark is offline
Old 01-21-2009   #5 (permalink)
Trouble Maker
Phoenix's Avatar
Real Name: Tony Holcomb
Exactly what I was thinking. Tires do go flat and you might need to lift the car up just to put in some trans fluid.
Phoenix is offline
Old 01-21-2009   #6 (permalink)
Trouble Maker
Phoenix's Avatar
Now's a good time to bring these up. I was wondering about the fesibility of using them on an opel. They're very expensive but the concept is interesting.
Phoenix is offline
Old 01-21-2009   #7 (permalink)
Real Name: Joe S.
Dirk is on a distinguished road
I dunno, those look like they're only for spreading the stress of jacking the car up. From what i understand the opel issue is rusting of the jackpoints.
I love opels AND buicks!
Dirk is offline
Old 01-22-2009   #8 (permalink)
OpelJim's Avatar
OpelJim
about to cut up a 73 Manta
Dean
If you want the OEM jack points to weld back in place
then let me know via phone 760 497 5360 Jim M
1st paid 1st delivered
For the front pair custom cut $85.00 each
OpelJim is offline
Old 01-22-2009   #9 (permalink)
Kalifornia Kid
DennisGardiner's Avatar
RallyeBob has posted in another thread (can't remember which) pictures of his 'built' (and I mean built) jack points for the 50 series Opels.
Bob's da Man!
DennisGardiner is offline
Old 01-22-2009   #10 (permalink)
Kalifornia Kid
Okay found it:
Old 01-22-2009   #11 (permalink)
Okay found it:
HTH,
Old 01-23-2009   #12 (permalink)
manta73wi's Avatar
manta73wi
Dean, I would recommend you certainly replace the jack points. As the others have said, the structural rigidity is needed, and keeping that part of the car stock does have its benefits should you decide to sell at some point in the future. Sounds like Jim M has the parts you need. I got some a few years back in a group buy on this site; otherwise they aren't real easy to find in the US in my experience.
-Jeff W
manta73wi is offline
Old 01-23-2009   #13 (permalink)
Manta Owner
deanh74_2's Avatar
Thanks for the help.
Thanks for the help guys, I think... .
You have given me something to think about. I am still unsure which way I will go but, I am leaning towards replaceing the jack points. I will also have to see if I can afford to replace them also. I have a limited budget and it isn't getting any bigger any time soon.
Thanks,
Dean
Old 02-05-2009   #14 (permalink)
Gary Sullivan's Avatar
Gary Sullivan is on a distinguished road
Jack pad swap
Anyone know if jack pads from the Manta fit the Ascona's well? I don't have a Manta to check closely.
NYAsconaGuy
Gary Sullivan is offline
Old 02-05-2009   #15 (permalink)
As far as I know, they are the same.
Old 02-05-2009   #16 (permalink)
Yup, Manta, Ascona and wagon are the same, 1971-1975.
Old 02-05-2009   #17 (permalink)
blancojp's Avatar
Provided Answers: 10
I rebuilt my driver's side unit on the Ascona since it was rusted beyond repair.
I did however add 1/4" rebar to the rockers at the same time since I will be changing the engine at a later date.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 02-05-2009   #18 (permalink)
blancojp's Avatar
Pics of course
Here are a few pics of the before and after.
JB
blancojp is offline
