Old 07-01-2009   #1 (permalink)
Sparky73's Avatar
Real Name: Jon
Sparky73
Unanswered: Removing Belly Pan, Spot Welds?
I am finally starting on my GT again! I got the motor pulled yesterday, so I can start body work. The belly pan needs to come off.. but I have never attempted to remove panels like this. Should the spot welds be drilled (what size bit) or ground off?
I searched the forums with no luck, so if there is already a post about doing this, please send me that way.
Current
1970 GT; Under Construction
Previous
1969 GT; Street/Strip Project
1969 GT; Black Parts Car
1969 GT; White Parts Car
1972 GT; Red Parts Car
Sparky73 is offline
Old 07-01-2009   #2 (permalink)
Uber Genius
First opel 1981's Avatar
My son is a body guy and he says there is a special drill bit for drilling out spot welds.
Otherwise, I used a 1/4 inch bit with good results.
First opel 1981 is offline
Old 07-01-2009   #3 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
before belly pan removal
should we tack weld support braces in to hold the front end in place before the belly pan is removed?
Projekt 2009 - Der OPEL GT
Other Cars:
2006 Solstice (Aggressive)
2010 Fusion Hybrid (White)
LINK to my picture Albums
sawdust is offline
Old 07-01-2009   #4 (permalink)
Jon
Lots of planning on how to remove the panels before any work begins.
After the planning a very sharp center punch and the closer to center of the weld the better. I used a 5/16th cutter and plenty of patience,blood,sweat and tears.
Old 07-01-2009   #5 (permalink)
Sparky73's Avatar
Real Name: Jon
Sparky73
What do you mean by this?
Current
Previous
Sparky73 is offline
Old 07-01-2009   #6 (permalink)
GA219B, Kit, Hole Cutter
This is the unit I used on the 70 GT with good results.
Jack of all trades master of none..well maybe one or two areas
ok back to none again :-)
Old 07-01-2009   #7 (permalink)
Have a read of the "sticky" thread at:
http://www.opelgt.com/forums/2d-body...r-arch-gt.html
and look at the photo in post #19 for a spot weld drill.
Then look at my photos at
MIG Welding Bodywork 2007 - Opel Photo Gallery
for very explicit photos (ooohhh! almost porno!!!) on how to remove a belly pan. And to repair it as well.
Old 07-01-2009   #8 (permalink)
opelspyder's Avatar
Belly pan removal.
Not a fun task, but it can be done with a couple tools. There is not a need to support anything on the front end, as the belly pan offers no support to the front end, it is mearly a dressup item, and once it is removed, you will see how flimsy it is.
You can buy a spot weld cutter (there are several out there) I use a Rotabroach/Hougen brand that is actually not a drill bit, but a round cutter bit. These last a long time, but the kit is 79-100 for 5 different size hole cutters. There are drill bits made for removal of spotwelds, but I never liked them. Another way is to pilot drill them, and grind them out with a tapered cutter (you are going to reweld the hole up anyways.
You will also need a cutoff wheel just to cut off the 2 inch part at the front fender lip where it is brazed from the factory.
I love body chisels!!!, Once you have the spotwelds drilled out, take a body chisel, (Offered by Steck Co), and hammer in between the seam (These are called seam busters as well). I then hammer along the flat side of the buster to cut between the spotwelded seams of the two panels. Just do not get too crazy. In the restoration of the yellow GT I am currently doing, look at the part where I am replacing the rear deck of the car, I picture these tools and what they can do.
Keith
opelspyder is offline
Old 07-02-2009   #9 (permalink)
Jeepsbeme is on a distinguished road
If this is pretty much one of the few panels you'll be removing, you can probably get by with just a single tool. try: EW Skip Proof Spotweld Cutter
They also carry the body chisel opelspyder raves about!
Brian B - SE Michigan
My "Fun Fleet":
1973 Opel GT - Completed
1976 AMC Pacer - Completed
1970 Jeepster Commando - Under Construction
1952 Willys M38 - Completed
Jeepsbeme is offline
Old 07-02-2009   #10 (permalink)
Eastwood has good quality tools for sure, but at $31.49 USD for only one 3/8" cutter it's a bit pricey. A more economic option, at half the price at $14.99 CAD (about $12 USD) for TWO cutters (one 5/16", one 3/8"), and each cutter has two cutting sides (so effectively four cutters) is this one at Princess Auto:
2 pc spot weld cutters | Drill Accessories | Powertool Accessories | Tools | Princess Auto
This is what I used for all of my spot weld cuts (probably over one hundred welds) and I only used three 5/16" cutter sides (two cutters, one side left unused). I found that the 3/8" cutter left too big a hole for most spot welds. I like the idea of a pilot bit on the Eastwood cutter versus the retractable pilot centre point on the PAL cutter, but I found that if I centre-punched each spot weld ahead then the cutter worked flawlessly.
JM2CW
Old 07-02-2009   #11 (permalink)
tomking's Avatar
I have both types of spot weld cutters. Both have their pluses and minuses. The removeable/reversible type Keith mentions above is much more fragile and easier to break. So with that one take care.
TMK
tomking is offline
Old 07-02-2009   #12 (permalink)
opelspyder's Avatar
Those reversible bit cutters are junk, as they are fragile if you get the slightest bit sideways, and it is easy to do when you are not working on a true flat surface. I have yet to chip a Rotabroach cutter tip, and I use them for quite a bit of other operations. Work good for an O'ring groove cutter also
Old 07-02-2009   #13 (permalink)
Um, not as durable perhaps, but junk? Au contraire mon frere. For a few spot welds, they work fine. Heck, I did about a hundred spot welds with three cutting edges. I found that the trick was indeed to be gentle, keep the cutter "flat", and don't get ramy. I found that my cordless drill provided sufficient force and speed. Too much of either and yes, I chipped the cutter teeth. If $31 for single bit isn't too expensive, then sure, get the good stuff. Otherwise, at a fraction of the cost, the reversible bit cutters are adequate IMHO.
