Unanswered: Manta Front End Rebuild
I'll be going with the OGTS bushing set for the control arms and that seems pretty straight forward. Here are my main questions: 1). Sway Bar Bushings - I've read here that it's best to go with the rubber ones, but at which location - the body or the lower control arm or both? My stock bushings that attach the bar to the body look OK. Hard to tell the condition of swaybar-control arm bushings but I want to go ahead and do whatever I need to do while I have it apart. 2). Tie Rod ends. OGTS has the tie rod ends listed as discontinued (both inner and outer now). I've managed to find the outers listed through internet sources, but the inner ones seem impossible to find. Anyone? I'll post additional questions I'm sure! Todd
#2 (permalink) | ||
Although the rear bushings on the front sway bar are not as prone to this phenomenon, I'd consider changing them too. I mean, once the bar is off the car and the forward bushings are removed, now's the time to do it!
Bob |
#3 (permalink) | ||
Thanks for the info! Todd K.
#4 (permalink) | ||
Thanks!
#8 (permalink) | |
a retraction
Based on that, I'm sure the reproductions will be better than what's on your car, especially if they are original. |
I've managed to remove all the control arm bolts with little difficulty (gotta love air tools!). The sway-bar-to-control-arm bolts were toughest.
Before I do my typical stunt of breaking stuff, how do I remove the sway bar from the lower control arms now that I have the bolts out? Does it have to be pried out? Also, for the control arm bushings, is it best to burn them out? That was the method recommended years ago when I was replacing the bushings in GT control arms. Todd
Todd,
Put the sway bar to LCA bolt back in about half way. Now go get a big hammer and pound away. Just remember don't do anything to destroy the threads inside the end of the bar. Oh yea use lots of PB Blaster
Paul Last edited by Paul; 05-15-2006 at 11:20 AM. |
#11 (permalink) | |
Site Admin
I picked up a 20 ton press at a swap meet last January. Cannot believe how many times i have used it already. Sure does beat the old bolt and socket in a vise trick! |
Todd, if you have a Dremel or similar hi-speed moto-tool your can use the Dremel spiral saw, it's almost like a drill bit but much coarser and the cutting edge is all along the flutes, and just slide it along the rubber and it will take it out nicely. Similar to drilling a bunch of holes in the bushing, but just one action. Run the bit down into the rubber then just go around the center and your done. As with the GT bushings you'll need to clean up the excess with an exacto knife, but it's a lot cleaner and faster than either burning or using a small drill bit lotsa times. HTH.
#13 (permalink) | |
Todd
