Old 08-23-2006   #1 (permalink)
David12345 is on a distinguished road
Unanswered: Upper control bushings
Recently bought a '73 GT and have not gotten a good manual yet. The car was pulling to the left, so I took it to the local garage for alignment. On the drivers side, there is 1 spacer about 1/2 inch thick on the right side, and none on the left or on the passenger side at all. I took pics, but haven't been able to upload them yet. Any suggestions or pics that would show each item that is installed?
Thanks,
David
David12345 is offline
Old 08-23-2006   #2 (permalink)
pics
I still can't figure out how to show the pics, but they are in my album
David 12345. Help!
Old 08-23-2006   #3 (permalink)
David, on the left side of the home page is the Opel Tech Center block, click on the Interchange Parts Manual and you'll be able to down load an Illustrated Parts Breakdown of the front suspension in a PDF file. There are 2-3 pages of the front suspension that may help. Also, when you post a thread, if you scroll down the page a bit, you'll see the manage attachments button. Click on that and you'll be able to attach pics from your files to the thread. You may have to resize the pics for them to be accepted but any photo program should do that, if you don't have a program to resize the pics, Irfanview can be downloaded from this site to do that for you. HTH.
Old 08-23-2006   #4 (permalink)
Thanks,
David
Sounds like the caster is out. Assuming the bushings themselves are in reasonable order, have the alignment checked.
The upper a-arms can be shifted fore and aft to adjust caster....this is done by varying thickness' of spacers on the upper control arm shaft. The cumulative thickness (for both sides) should be .480".
Old 08-23-2006   #5 (permalink)
Essential Info ...
Here is a thread about Castor adjustment:
http://www.opelgt.com/forums/3a-fron...-question.html
It is quite possible that there needs to be different washers on LH & RH sides as the whole suspension is very prone to bending and bolts working loose - thus enlarging bolt holes and letting things move about.
Get yourself a copy of Brookland Books "Opel GT Owners Workshop Manual"
It is still in print and often available on EBay. It has excellent line drawings of most bits that need repair and good explanations. This book:
http://www.opelgt.com/forums/101585-post3.html
Also go to OpelGT.com Lite on the LHSide of the Home page and seek out front suspension under Section 3A. A look through the threads & postings will be extremely useful.
Castor specs for GT: unladen: + 0deg 40' to + 3deg 40'
normally loaded: + 1 degree to + 4 degrees
Quite an allowable varriation - shoot for around +2 degrees LHS +2 1/2 deg RHS to allow for the camber (curve) of the road surface.
Old 08-24-2006   #6 (permalink)
Viking
hallgeir's Avatar
Real Name: Hallgeir
You can also order it from their website: http://www.brooklands-books.com
Hallgeir
Opels now:
Previous Opels:
hallgeir is offline
Old 08-25-2006   #7 (permalink)
I'm gaining .. on the passenger side of the car the shims (toothed washers for castor adjustment equaling .48") were not there, causing the control arm to be squeezed in by the bolt. Ordered from OGTS.
I am still looking for a good manual. It seems there are so many various manuals and I want to get the right one. I went to Brooklands site but did not come up with OPEL GT Owner's Workshop Manual" OWM727 .. other names and numbers, but not that one. I've looked for purple books, green books, etc .. and I can't seem to match names/colors/numbers up..any good advice would be appreciated .. and I certainly appreciate all that has been given.
David
Old 08-25-2006   #8 (permalink)
Viking
hallgeir's Avatar
Real Name: Hallgeir
It`s there...
David, go to the website link in my post # 6. At the top left corner click "cars by marque" and select Opel. Scroll down at the right side of the screen, and you will find it.
Hallgeir
Opels now:
Previous Opels:
hallgeir is offline
Old 08-25-2006   #9 (permalink)
Lots Here!
Some closer to home?
http://cgi.ebay.com/ebaymotors/68-73...spagenameZWD1V
Old 08-25-2006   #10 (permalink)
soybean's Avatar
David
Here's another site for manuals. HTH, Jarrell
http://www.books4cars.com/result1.as...mageField.y=91
soybean is offline
Old 05-13-2007   #11 (permalink)
jordan's Avatar
I only have (2) crowned washers, (1) thick spacer, (1) thin spacer for either side of the UCA. Is there any consistent configuration for the spacers of the upper control arms? Is there a way to set caster when the suspension is out of the car with out an alignment set up?
1970 Opel GT 1.9
1980 Moto Guzzi V50
2000 Saab 9-3 2.0 turbo
2000 KTM 200 exc STOLEN
jordan is offline
Old 05-13-2007   #12 (permalink)
Not accurately. I've found that there are not two GT front crossmembers that are alike. The upper pivot tubes are almost always welded in at different locations, which alters the caster angle.
That said, just put the thick washers at the 'rear' of the crossmember, and the thin ones at the 'front'. Then, when it's in the car, have the alignment checked, and alter it from there as needed.
For more spirited driving, place ALL the caster shims to the rear of the car, and none up front. (I tend to go one step further and machine down the front of the pivot-tube and add more rear shims to gain even more caster). Yea, I like caster!
Check for a-arm clearance issues if you go this route however. I like a lot of caster because it centers the wheel better, and provides for some camber-gain on turn-in, which the GT sorely needs. If you need, I have some 12mm ID washers that are .112" thick (just under 3 mm or .118"), and I use these to alter caster on both GT and Manta front suspensions. I could bring a handful with me to Carlisle, if needed.
Old 05-13-2007   #13 (permalink)
Alignment
(1) Wheel alignment, is meant to be done with the suspension on the car, as only then can actual wheel deflection can be measured with reference to the road surface.
(2) On a GT upper front suspension, there are 4 washers (which go on the outside of each bushing), there are 2 wider toothed shims (which go on the side of the cross member towards the rear of the car), and 2 thinner toothed shims (which go on the side of the cross member towards the front of the car.
These details and installation procedures, were covered and illustrated, in the GT Front Suspension Tech Tip article of the OMC Blitz newsletter of December 2006.
Anonymous D is offline
Old 05-13-2007   #14 (permalink)
jordan's Avatar
Does this look about right bob? My shims only totaled .470" will .010" from .480" matter? The left of the photos is the front of the car.
1970 Opel GT 1.9
1980 Moto Guzzi V50
jordan is offline
Old 05-14-2007   #15 (permalink)
Looks Right ...
That is where Bob has advised you should put them. Have to check the alignment after the suspension is on the car to make sure nothing is bent so much that it is all out of specification though. A wheel alignment check is pretty much a necessity after a front suspension rebuild amyway!
