Old 06-05-2007   #1 (permalink)
Trouble Maker
Phoenix's Avatar
Real Name: Tony Holcomb
Unanswered: What is this made of?
I'm just about really to put my front suspension back under the car. It has come down to painting a few last little things up and making a few new gaskets.
This is the one that I am wondering about. It cushions the body on the front suspension crossmember. At first, I thought that it was made of multiply cardboard but now I'm not so sure. Is it wood?
http://i76.photobucket.com/albums/j5.../Gasket001.jpg
http://i76.photobucket.com/albums/j5.../Gasket002.jpg
http://i76.photobucket.com/albums/j5.../Gasket003.jpg
Phoenix is offline
Old 06-05-2007   #2 (permalink)
All I can say is that it is some type of fiber resin board. It felt like it would break if you bent it much. I wouldn't worry about painting them, just clean them up. They are sandwiched in between where they won't be seen anyway and you know they won't rust.
hrcollinsjr is online now
Old 06-05-2007   #3 (permalink)
There are two words that describe those shims. One is "Micarta", the other escapes me. Ah, just remembered it's "Phenolic" Vey hard stuff and not flexible at all. Harold is right, just put them in between the "frame" and the suspension beam and tighten up the bolts.
Old 06-05-2007   #4 (permalink)
Manta Maniac
Rionart's Avatar
Exclamation
They are made of Opelidium, make sure you wear gloves when you handle them, if you allow Opelidium to come into contact with bare skin it increases your susceptibility to advanced Opelitis....
How do I know this....my Dad thought one would make a good teething ring for me....
Politicians and diapers have one thing in common. They should both be changed regularly and for the same reason.
Rionart is offline
Old 06-05-2007   #5 (permalink)
tomking's Avatar
I replaced mine with conveyor belting I cut to the same size.
TMK
tomking is offline
Old 06-05-2007   #6 (permalink)
I seem to recall reading that the phenolic spacer was simply a way to slightly raise the front end in order to meet US bumper height requirements. True or not? In any event, I can't see that it provides much functionality other than that, so couldn't it just be left out, thereby lowering the front a full 1/8 of an inch ?
Old 06-05-2007   #7 (permalink)
www.opelgtworld.de
opelgtworld's Avatar
opelgtworld
I vote for not true
It absorbs vibrations.
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)"
opelgtworld is offline
Old 06-05-2007   #8 (permalink)
Phenolic is a hard resin based material, with a cloth weave inside. I agree that these things appear to be made from phenolic or a very similar material. It is way too hard to be a cushion of any sort, but I still don't know the reason that they exist in the suspension.
Old 06-05-2007   #9 (permalink)
Maybe it's some sort of chafing pad, to keep meteal to metal wear out of the loop.
Old 06-05-2007   #10 (permalink)
Trouble Maker
Phoenix's Avatar
I'd like to replace it. If it was cardboard, I had a corner brace/protector for pallets that carry things that dont want to be impacted on the side that I could cut to match. They also have ones in plastic for the pallets of bananas. Both are about an 1/8th thick and the carboard one is not corragated. My uncle(not BSQ4, I've got 5 on my moms side) looked at it and immediatly thought that it might be fiber resin.
Opelidium, very interesting Rob. That might explain why I want every Opel that I set my eyes on.
A year in, and already I have 2 GT, and really have a Manta jonesin'.
Phoenix is offline
Old 06-05-2007   #11 (permalink)
jordan's Avatar
I was curious about this material too and what it should be replaced with, mine broke apart despite my careful handling and fragments have been lost. Could some dense rubber or polyurethane sheet work? also for the foam rubberish sheeting that was in between the shock tower "cups" and the body; could they be replaced with craft store foam rubber?
1970 Opel GT 1.9
1980 Moto Guzzi V50
2000 Saab 9-3 2.0 turbo
2000 KTM 200 exc STOLEN
jordan is offline
Old 06-05-2007   #12 (permalink)
Trouble Maker
Phoenix's Avatar
For that piece, I was just going to use rubber gasket material and cut it to match. Everyone that I've seen was junk and came of in pieces, so I cut it to match the top shock piece.
The spacer is hard, so it shouldn't give. Can't use rubber.
It's load bearing, so it can't crack. Can't use wood.
It's exposed, so it needs to be somewhat water resistant. Can't use the multiply cardboard.
I'm going to ask my uncle about the fiber board, and also get one of the plastic corner pieces from the banana pallets.
Phoenix is offline
Old 06-05-2007   #13 (permalink)
www.opelgtworld.de
opelgtworld
The damping element between the front suspension cross member and the body
original was made of pressed gasket paper. After 30 years it can look like
wood
The gasket for the damper ring retainer (rubber) in the wheel housing could be replaced with cut out rubber shoe soles from your shoe repair shop.
This was done to keep unwanted vibrations away from the body.
Old 06-05-2007   #14 (permalink)
opelspyder's Avatar
Spacers
The original spacers do not go bad, so why replace them? Just reuse them. If you use another material, it might make the ride stiffer. I would run them again as I cannot see any performance upgrade here.
Keith
opelspyder is offline
Old 06-05-2007   #15 (permalink)
jordan's Avatar
Keith
The reason is because for many of use they broke apart when removing the front suspension unit so we are trying to find a suitable replacement, I don't think anyone here right now is trying to replace them for a performance upgrade or for the heck of it.
1970 Opel GT 1.9
1980 Moto Guzzi V50
jordan is offline
Old 06-05-2007   #16 (permalink)
Just go to McMaster.com and buy this product number 9322K13
Old 06-06-2007   #17 (permalink)
Trouble Maker
Phoenix's Avatar
Jordan, I was just going to cut some thick rubber gasket material available at ACE Hardware in the Plumbing section. But here are two places that sell it.
Lenk item 5/110
Geman Ebay
My rectangular dampning elements are decent but aren't evenly flat anymore. They came off whole. But I have just about everything else new, might as well have new of this item as well. Better to replace it now, then have to replace it if it were to go.
I'm going to look in to the fiber board and the garolite piece.
Phoenix is offline
Old 06-06-2007   #18 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Opel GT Source sells these upper shock tower gaskets now. I just got mine and they are made of some sort of rubber product. They said that they just started selling these gaskets so I doubt they will be in their catalog. You will probably just have to ask for them.
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 06-07-2007   #19 (permalink)
Ricky Slade is on a distinguished road
I think the Phenolic idea is closest to correct. The original material I beleive is called Bake-O-Lite and yes it was a phenolic type plastic. It is still used in the electric industry today and has a very high resistivity. Other words a darn good insulater. I rebuilt a pair of leaf springs on my 1956 Chevy and replaced similar pieces with products supplied by Classis Chevy International. Better known now as Eckler's. I found the same rebuild items on page 197 of there recent catalogue. Item number 21-39 thru 41. Cost is around thirty bucks. This stuff is now made, I think from a Teflon type product and works kinda like a urethane bushing. Dry lubrication. No metal to metal and thus no hanging up due to rusting and pitting and also no squeeks. Most likely a good investment.
Ricky Slade is offline
Old 06-07-2007   #20 (permalink)
Bakolite is VERY brittle and I think would crack too easily for this application.
Old 06-07-2007   #21 (permalink)
Mike's Opel Shop
opellane's Avatar
I got my Front Axle Spacer Plates from Suselbeek in the Netherlands, Reproduction plates brand new. I think they were about 15.00 Euro's, a pair.
Bought two pairs the part # is 105090. They take a bit of time to get, but well worth it. I think they wait to ship when the euro to US dollar is on the rise, anyway you got to get their FULL COLOR CATALOG it's awesome. I order online at opelgtparts.com and parts come in about 5 to 6 weeks. Unless they are away on Holiday. I hope that helps.
MIKE
1969 Opel GT in Paint Shop
1973 MGB, Red, Weber 38DGES
I have pride in my rides
opellane is offline
Old 06-11-2007   #22 (permalink)
heimue's Avatar
I found your dampers at Splendid Parts in Germany. The black seals are 7 Euro each, the green dampers 4 Euro each, The set (2+2) is 19 Euro. It doesn't specify what it's made out of, though.
Dieter
heimue is offline
Old 06-11-2007   #23 (permalink)
jordan's Avatar
Dieter
Green stuff, and black stuff, duh
1970 Opel GT 1.9
1980 Moto Guzzi V50
jordan is offline
Old 06-11-2007   #24 (permalink)
jordan's Avatar
Jeff, This "Garolite" stuff that is that mcmaster part number seems to carry many of the same propertys as phenolic and I thought that it was decided that phenolic is far too hard and brittle for this application. I have lots of phenolic from previous projects if it is determined that it is suitable, I believe that this material is placed between the "frame rail" and the front suspension mount to create a conforming surface for both components ie "gasket." Though I could be way off in it's purpose, in which case I think it needs to be determined before a material can be decided. (I still think we are getting way too far into this, but it's the way I am to pick everything apart and I guess it is the same for others )
1970 Opel GT 1.9
1980 Moto Guzzi V50
jordan is offline
Old 06-11-2007   #25 (permalink)
Jordan, IMHO, it's nothing more than a pad to prevent rubbing between the suspenson crossmember and the "frame" rails. It, (phenolic) is used for that purpose in the aerospace industry. You'd have to see what happens to the panel structure on an aircraft when a panel with a zillion screws holding it in place vibrates against the structure to understand the importance of using it as a chaffing pad. Without the pad, the panel, made out of aluminum will eat through the steel structure and the panel as well.
