Unanswered: front addco sway bar reasurrance
My car really liked it. So much that I would next want to try the OGTS version, which is a larger diameter, thus stiffer, as I understand.
We have it set up a little differently than what would normally be done for street use, we have it slightly preloaded. But we found that through the turns it was causing the entire front end (both sides) to dive about a half inch more. That's a good thing, especially in a car that is touchy about pushing. Sorry I can't report on how it might help in a right hand turn, I've never tried that in a GT.
long time Opeler
Installing sway bar's to your GT will be one of the best single suspention mod you can do. The car should have come stock with one IMHO. I agree with Jeff about the the one from Opel GT Source.
Theres only two alignment settings on the GT ..camber and toe. Toe 1/8 in camber theres only two settings go for the most negative for handling. For tire wear as close to zero as possible..but you'll get some squirm. Now for the bad part if the ball joints,tie rod ends, or the bushing are loose... Last edited by wrench459; 05-29-2008 at 10:30 PM. |
I like mine a little on the loose side..backend comes around before the front. That way I can hit the brakes and make the front turn. Dirt is in my blood Last edited by wrench459; 05-29-2008 at 11:17 PM. |
Actually camber, caster, and toe are adjustable on a gt's front suspension. The castor is adjustable with shims on the upper control arm and makes a very big difference; negative caster and more toe in will make a much more rapid turn and also recenter much better. I prefer the handling is this configuration much more over stock.
#8 (permalink) | |
POSITIVE caster will center the wheel back faster. IMOA All personal preference of course. Bottom line we now how to tweek the front end And your going to ask a flat rate mechanic to do what? On this side of the pond it only cost 49.99-79.99 for a typical two wheel First question ? whats an Opel they dont have a clue .. And you what them to align the frontend ohhh dont get me started.. do I need to talk about four wheel alignments? Last edited by wrench459; 05-30-2008 at 12:19 AM. |
'72 Opel GT (Sara)
You can go faster around corners - what's not to like?
I like 'em!Matt
#10 (permalink) | |
The down side to more positive caster is increased steering effort, however the biggest benefit (and the reason I always max a GT's caster) is that there is a bit of negative camber gain to be had by running a lot of positive caster. So you can reduce static negative caster which improves tire wear and straight line braking due to better contact patch, but keep the handling when pushed hard. As far as toe adjustment goes, for any street car you really must run toe-in. Toe-out aids steering response for racing, but it is twitchy and will follow every groove on a roadway. It also wears tires amazingly fast... GT's don't need much toe-out anyway, they have plenty of Ackerman built into the steering geometry (inside tire turns more degrees than outside tire in a curve). However, Kadetts have different steering arms, and not only is the steering slower (longer arms), but there is virtually no Ackerman. Bob
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by RallyBob; 05-30-2008 at 12:18 PM. Reason: multiple spelling errors..I was tired last night! |
#11 (permalink) | |
Toe is the major cause of tire wear hands down..be it out or in. |
#12 (permalink) | |
Didn't you mean to say Camber here?
Paul |
#13 (permalink) | |
GT Owner
A booklet by Addco indicated that if your GT is lowered, you should adjust the length of the center bolt and tube spacer to accommodate the height change between the chassis and the suspension. Apparently, Addco sells urethane replacement end-links for this purpose.
Bob Last edited by opelgt722002; 05-31-2008 at 01:17 AM. |
#15 (permalink) | |
#17 (permalink) | |
I hope they didn't charge you for a '4 wheel' alignment. Modern cars with independent rear suspension and adjustable toe links can be aligned out back. Primarily camber and toe.
But solid axle cars with fixed-length trailing arms and panhard bars cannot. They can check it, but they can't change the rear alignment without aftermarket (read as: custom-made) parts. HTH, Bob
#20 (permalink) |
C'est vrai!
#21 (permalink) |
So what they did was check to see if the car is "square". Nothing wrong with that, but, what did they find and what would they do about it?
Glad you're happy with the sway bars. Once you understand exactly how the transverse front spring works (or doesn't) and what the sway bar can do to help it, it just makes sense to use it! I haven't tried a rear one, for what we do it shouldn't be needed. But you never know unless you try it, what works for some might not for another. Every car is different, every driver is different.
No Opels were harmed in the filming of this movie. However two Mustangs, a Pinto, and a Capri were hospitalized. One Mustang was euthanized the next morning. Last edited by jeff denton; 06-01-2008 at 04:14 PM. |
#22 (permalink) |
Does anyone have experience or theory re using front (front only) sway bar from 1.9 gt on 1.1? I have a used front & rear bar set complete except for rear axle welded brackets. Was a lighter/less stiff bar ever available for 1.1? Are aftermarket bars better for lighter car? Car is all stock except for p175/80r13 tires, no brute power here, but good front to rear weight balance, just looking for stability in the twistys. ??
#23 (permalink) | |
#24 (permalink) |
front swaybar
I have just the front swaybar installed on my GT at this time.
When I get the time I will add the rear. So far,with just the front bar installed,I have noticed quite a bit of improvement in cornering...car stays a lot flatter.
#25 (permalink) |
As you go around a corner, the outside spring is taking all the body roll, so that side's suspension is going into "full bump". The sway bar takes some of that action and transfers it to the other side. Puts it into some "bump" also. The whole front end dives. Weight is transferred from the rear to the front, and if the setup is right, camber gain occurs at both front wheels. If the springs are stiff enough, neither side will hit the bump stops. If bump stops are hit, "push" will occur for sure.
To dial it in, one thing you must know is if the bump stops are being hit. Suspension travel measurements are helpful too. Anyone want to know an easy way to measure your front suspension travel?
