Unanswered: Poly Bushings question and Torque Specs
Anyway, does anyone know the torque specs for the upper control arm pivot bolt (my book calls it the upper control arm shaft) and the bolts on the side of the lower control arm that hold in the bushings? I am hoping that once I get these things all torqued down correctly, everything will fit together more tightly. Right now I just have the nuts on the upper pivot bolt on finger tight, but the control arm can slide back and forth along the bolt because there is so much extra room (I took digital pictures of it before I took it all apart, so I know it is put together exactly like it was before). Also, on the lower control arms, even though I have the bolts until it feels like they have bottomed out, the bushing on one side doesn't look like it is all the way in. Has anyone else had experience like this when installing poly bushings? Pete Sprenger SkiWaNow@comcast.net 1972 Opel GT |
