Old 12-19-2005   #1 (permalink)
duvel's Avatar
duvel is on a distinguished road
Unanswered: missing bushing ?
I'm checking my suspension when my frontweel is removed.
I notice that I miss a bushing on both sides.Is that normal or is it a coincidence that the same bushing is missing on both sides?
You can see the missing rubber on the right site of the A-arm
duvel is offline
Old 12-19-2005   #2 (permalink)
Duvel, it appears the bushing lip is worn away on your upper A-arm. Those bushings are sleeves that go through the arm ends with lips on both ends. OGTS has, I believe, original style bushings and the newer Poly Bushings, and very comprehensive instructions on how to install them. HTH
Old 12-19-2005   #3 (permalink)
Yep!
That is called a "rubber damping ring" by Opel and is only fitted to one side!
Er! one side of each RH & LH sides of the car ........ you got it
Old 12-19-2005   #4 (permalink)
duvel's Avatar
So, it means that I have a correct set up because the other missing bushing is on the other side of the car
duvel is offline
Old 12-19-2005   #5 (permalink)
duvel's Avatar
i mean damping ring
duvel is offline
Old 12-19-2005   #6 (permalink)
soybean's Avatar
Enclosed is a picture of a disassembled upper control arm that shows the single bushing I believe you are speaking of. It is to the right in the picture. Hth, Jarrell
soybean is offline
