Front Suspension Shimming
Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By P.J. Romano
  • 1 Post By itb gt
  • 1 Post By hrcollinsjr
Thread: Front Suspension Shimming
    Nov 2007
    Cöllingswööd, NJ
    9,569
    Gördö
    6
    I read a post by Frozen Tundra a while back where he said something about shimming the front suspension. I don't know what he did and I could just ask him, but I figured that maybe this deserved a thread.
    I had to put a stack of shims on the right side of my Red Baron car because the frame rail that the suspension bolts to was inaccurately repaired by the PO of that car. But I'm suspecting that Jimmy shimmed his for a different reason.
    My thinking is that we could get more caster adjustment if we shimmed the front mounting bolts on each side with a washer or plate between the frame rail and the suspension. Just shimming the front bolting area would tilt the front suspension backwards a little. The only oem adjustment is the lame washer swap at the A-arms.
    I'm curious about this as an experiment to see if it would help my steering return to center after a sharp turn better. My negative offset wheels have a tendency to want to oversteer on sharp turns and you have to fight them a little bit to get them to return to center.
    Aug 2006
    Goderich, Ontario Canada
    2,647
    P.J.
    Interesting idea but there is easier way to increase the caster over Opel's pretty limited adjustment range. First, move all caster shims to the rear. You may go even further and shorten the pivot tube at the front and add the same amount of shims at the rear. Every 3 mm (1/8") will give you approx. 2 degrees of caster.
    The Scifi Guy likes this.
    Nov 2007
    Cöllingswööd, NJ
    9,569
    Gördö
    6
    Oh, I can do all that stuff? Excellent!
    Jun 2006
    N.H
    142
    Caster
    Yes,it works.A friend who races in Germany uses a wedge shim to adjust caster.He said it works great very hard for tech to find.
  7. #5
    Jan 2003
    Chapel Hill, TN
    7,771
    Harold Collins
    I did this with my first GT. Get a caster reading and have custom wedges/shims made to get the caster you want. My caster was different from left to right so my two shims were different thicknesses.
  8. #6
    Nov 2007
    Cöllingswööd, NJ
    9,569
    Gördö
    6
    I've seen those long, slight tapering, wood wedges that carpenters use to get doors and windows just right and I have access to short, inch or so, metal wedges for mounting electric motors and such, but where can I get longish(6") very shallow rising metal wedges appropriate for shimming our from suspensions?
    Yeah, it's actually wouldn't be too much trouble for me to make my own metal wedges by sanding down some bars/strips of aluminum I have on my belt sander, but it would be nicer if I could find pre-fabbed metal ones.
    This looks like a job for Lindsay. He always comes through when I pose a question like this.
  9. #7
    Jan 2003
    Chapel Hill, TN
    7,771
    Harold Collins
    ....where can I get longish(6") very shallow rising metal wedges appropriate for shimming our from suspensions?
    At the time I shared a few students with a machine shop class. The drafting teacher down the hall drew up the dimensions. Ahh, times were good back then.
    1. Funk in the Front Suspension
      By The Scifi Guy in forum 3A - Front Suspension
      Last Post: 01-25-2015, 02:11 PM
    2. GT Front Suspension
      By blancojp (R.I.P.) in forum Performance Suspension and Braking Upgrades
      Last Post: 06-15-2014, 05:47 PM
    3. Shimming a starter on a 1.9?
      By lkyrog in forum 6A - Engine Mechanical
      Last Post: 04-13-2014, 09:58 AM
    4. front suspension conversion?
      By cycoGT in forum Performance Suspension and Braking Upgrades
      Last Post: 06-16-2007, 05:18 PM
