Unanswered: Problems setting caster
Angles
After years of nudging inanimate objects like curbs and potholes Opel front suspension components do get 'tweaked'
You can alter the castor by using tapered wedges between the suspension cross-member and where it bolts to the chasis to get the adjustment back into the range of the washers on the upper 'A' arm - or even move the lower 'A' arm on its four mounting bolts. Sometimes it is the 4 crossmember mounting bolts that are loose or the chasis rails themselves are rusty or crumpled a bit. There should be a red fiibre shim in there too. Just be sure that the suspension bushes are all undamaged and everything is tight .. especially all the nuts. HTH
Yeh, I just rebuilt the entire frontend. Took it out of the car and rebuilt it in the floor of my garage. I hadn't thought of shimming the crossmember to the chassis. I guess I would need to tilt the top of the cross member toward the back of the car, correct? I don't remember the red fiber spacer. Though I have seen it refered to in a couple of posts. What is the purpose of it?
"That IS the Question!"
No real explanation has come to light about the fibre spacers - the best we could come up with is that they act as insulators between the front suspension and the frame to reduce the transfer of road noise...
If we are talking about the same thing, the last two front suspensions I dropped had two pieces of metal? with holes in them that were on top of the crossmember between it and the body. Or am I missing something here? (Besides my mind. It comes and goes). I've never seen a red fiber spacer.
Jarrell
mine had the spacers and i think it was a quick fix for an engine bay height problem ,i cant think of anything else it could the 1.9 is tweaked to heck to fit it in to a gt , offset engine mounts, changes in inlet manifold heights all to make to tall an engine fit in to short a bay
On my front end the holes in the suspension crossmember (where the lower A-arms bolt in) were quite elongated. Is this normal? I don't know, but I made some little L shaped brackets with the right size hole, put them on top before the washer and nut, got caster to spec, and welded the side of the L to the crossmember. So the setting won't move, see?
Later I determined proper geometry for my application needed a 1/4" spacer between the the suspension and lower A-arm. This spacer then had the right size hole and also was welded in so it can't move. I can also testify that the upper a-arm is pretty weak, it doesn't take much to bend it's triangular shape out of whack. It also doesn't take much to bend it back, and a little plate welded onto it makes it look much sturdier! These little things are what you discover when you work a suspension as hard as I do, not to mention a bit of tire rubbing with Pintos and Mustangs...
#9 (permalink) | |
First of all, the lower a-arms on GT's bend very easily. So easily I've probably only torn apart 3 or 4 GT's that didn't have at least one bent a-arm. Secondly, the upper a-arm pivot point (metal sleeve welded into crossmember) can be way out to lunch as well. I suspect they didn't use an accurate jig (if any) when welding these sleeves in place. I once had 4 separate GT crossmembers in front of me, and I couldn't find two upper pivots that were welded in the same location. The fore-aft locations varied as much as 3/16"! I keep my eyes out for that 'perfect' GT crossmember that has two parallel-mounted upper pivots, but I haven't see one yet. On cars that are critical in this regard (racecars for example), I will cut and reweld the upper pivots so they match from side to side. Bob |
What is Castor & Camber??
Here is a good (simple) explaination in a link to a Corvette (Maxi GT
) site.http://www.melroset-tops.com/camber_...oe_defined.htm You will never look at a SuperMarket cart in quite the same way again!
