Unanswered: Broken lower control arm bushing bolt
Any ideas what to do? Do I need a new lower control arm!? Is there any way to get even the PU bushing out without damaging it? My brain is not functioning at the moment.
Have you tried hitting the broken bolt out with a center punch? This is very strange that this happened, were you using a true grade 8 bolt? Not a hardware store bolt I would hope; they may say that they are grade 8 but they are usually only a grade 5.
I would think the bolt would come out fairly easy by drilling and using a bolt extractor of some type. I have no advice for the bushing though. Wish I could be of more help.
Harold |
Thanks! Just got the end of the broken bolt out. It wasn't terribly stuck after all. I used original bolt which didn't even look especially rusty. Guess my next move will be trying to force rest of the bushing in (in vice or with hammer), getting a new bolt and wishing the inner sleeve still rotates well.
www.opelgtworld.de
Polyurethane bushings and an old bolt...
Do yourself a favour and use rubber bushings
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)" |
Increasing Levels of Violence ...
Just use a couple of thick flat washers and a short 12.9 grade cap screw on each side seperately - the long through bolt is only 8.8 grade and should never be torqued more than the specs - 33 lbs-ft
Hitting the bushes with a hammer is likely to bend the A-arm ..........
Thanks again for good information to everybody. Only new bolts I ordered were the long upper control arm bolts. Thought I could happily use everything else because nothing was stuck when I disassembled front suspension and all parts were pretty much rust free. Is there other bolts that really should be replaced?
PU bushings I chose because they were cheaper than rubber, easier installation and color matches the car. ![]() Edit: I used vise with rest of lower control arm bushings. One went in very nicely. 3 others not and stopped 2-3mm before bottoming. Maybe more force would have done the trick but I don't want to break anything more at the moment. Looked liked they were not completely straight with metal sleeve. Maybe control arms are somehow bent a bit? Luckily at least upper control arm and spring end bushings fit beautifully. Last edited by Lasse H; 04-17-2006 at 06:18 AM. |
#10 (permalink) | |
#11 (permalink) | |
Opel GT? Who makes that?
