Old 03-24-2008   #1 (permalink)
gtblast's Avatar
gtblast is on a distinguished road
Unanswered: Need help with ignition lock, no keys
I just bought a 70 GT and it came with no keys. The ignition and steering are locked and the front wheels are truned to the right some. This made it very difficult getting the GT up on my trailer. I would like to release the locked steering wheel so I can roll this GT of my trailer and move it around. I have removed the steering wheel and I am looking at the turn signal switch/ignition switch assembly, but can not get the ignition switch out. I have read the previous threads on this and I have the 70 service manual. They all talk about having to have the key in run, etc., but I have no keys. I know one option is to take a door handle and have a key made, in hopes that the door handles match the ignition switch. Is there any other way to release this locked steering other than by destroying a lot of good parts?
Thanks.
gtblast is offline
Old 03-24-2008   #2 (permalink)
GTer
pecje's Avatar
Real Name: Patrick
pecje is on a distinguished road
I haven't read the entire article but maybe it might help you:
http://www.opelclub.com/SteeringColumnApr2006.pdf
There's a part in it which handles the ignition switch.
Good luck
Definitely EX-member of the MWTE! © Mr. Corey Suggs
pecje is offline
Old 03-24-2008   #3 (permalink)
Option
You can also unbolt the steering column
(Remove the 4 bolts, including 2 "shear head" types, which may require drilling for an exractor bit, or to create a slot that a screwdriver can turn in AND remove the turn signal stalk AND remove the ground wire AND remove the 2 plastic wire plugs (white and black) from the side of the fusebox).
That allows you to turn the entire steering column, even when it is locked. It's not easy, but it can be done so that you can get a car to a trailer.
Anonymous D is offline
Old 03-24-2008   #4 (permalink)
tomking's Avatar
And after you get the car home remove the steering column and take it to a good locksmith and he can make you a new key to fit.
TMK
tomking is offline
Old 03-24-2008   #5 (permalink)
gtblast's Avatar
Thanks everyone for all the help. I did as suggested and dropped the column. Now I can steer the wheels straight and roll it off the trailer. This is most likely going to be a parts donor, so I may not worry about it any further for a while. Thanks again for all the help. By the way, this 70 is a real rust bucket and has a blown engine, so my search continues for a decent 70 GT project.
gtblast is offline
