Old 01-22-2006   #1 (permalink)
69whitegt is on a distinguished road
Unanswered: Steering column Interchangeability between '73 and '69?
Hi guys, I am looking to at a steering column on ebay but he said it came out of a 72 GT. Will it fit my 69 GT? thanks~
69whitegt is offline
Old 01-22-2006   #2 (permalink)
ayeropelgt is on a distinguished road
I think so....
As far as I know it should fit, I don't think that the steering column changed between years.
ayeropelgt is offline
Old 01-22-2006   #3 (permalink)
opeldean's Avatar
i think so.. confused when I compared the columns
I put 72 column in a model year 70(mfg nov 69),it worked fine BUT...the wires are diifferent in # and color at the plastic wire plug.
for instance..my early 70 wiring colors at the column doesn NOT follow the destec diagram.
opeldean is offline
Old 01-22-2006   #4 (permalink)
So you are saying all that is different is the color of the wires at the connector? everything else is fine?
Old 01-22-2006   #5 (permalink)
opeldean's Avatar
looks a bit different
plugs in and works fine, I made a call to Gil and he confirmed this last year befored I installed it.
so yes, they interchange w/o problems.
opeldean is offline
Old 01-23-2006   #6 (permalink)
PrOpeller
PROPEL's Avatar
As I recall, an extra wire lead for the seat belt warning buzzer (which a '69 does not have) is the only significant difference.
PROPEL is offline
Old 01-23-2006   #7 (permalink)
Detritus Maximus
I had a later steering column in my 69 for awhile. If I remember correctly, there is a slight difference in the color codes, but the only real issue was that one or two wires in one of the plugs (the black and white multi-plugs that connect into the fuse box) had to be switched around. One of the plugs does not use all six spots and it seems that I had to move one or two to match the plug in the fuse box. It may have been the dimmer switch wire.
The wiring diagrams won't tell you this. The 69-70 diagrams do not show the plugs, so the only way to tell is to look at the actual plugs and wires on your columns.
I could be wrong on this, but I do remember having to monkey around with the wires and the plugs.
"No, it's not fiberglass."
opelbits is offline
