Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 3 - Suspension and Steering > 3C - Rear Suspension
Old 10-23-2006   #1 (permalink)
David12345 is on a distinguished road
Unanswered: rear springs
I recently bought a '73 gt and think the rear springs are weak. I see OGTS has some springs to lower the front end, but I'd rather put the car back to it's original condition. And I don't know of any shops in St. Augustine that have equipment for checking these out. Any other thoughts for testing and/or where I can get new ones? I'm also curious about thoughts on the original exhaust system .. maybe need a different thread.
Thanks,
David
David12345 is offline
Old 10-23-2006   #2 (permalink)
Lindsay
GT Rear Springs (Options?)
http://www.opelgt.com/forums/3c-rear...t=rear+springs
Lindsay
71 GT
Lindsay is offline
Old 10-23-2006   #3 (permalink)
New thoughts?
I already read that thread and it did not mention if new springs were perhaps available. That owner wanted a slight rake .. I want normal.
David
Old 10-23-2006   #4 (permalink)
Viking
hallgeir's Avatar
Real Name: Hallgeir
They are available from Holland. www.Opelgtparts.com but they are expencive, and the shipping is too, I guess. I just bought a set from ebay, used ones that is. You can keep an eye there, they shows up from time to time. I have the 50 mm lowering springs both front and rear, but in my opinion they are far to stiff. It`s uncomfortable, and the exhaust touches the ground on every speed hump in the road. I will go back to stock.
Hallgeir
Opels now:
Previous Opels:
hallgeir is offline
Old 02-04-2007   #5 (permalink)
coil springs
I have emailed Welcome to Suselbeek Opel GT parts cars and service a couple of times to find out the cost and availability of the rear coil springs for a 1973 GT and did not get any response .. are there any other suppliers?
David
Old 02-04-2007   #6 (permalink)
When I cruise the junkyards I see lots of springs that could work, but as stated before the Taurus fronts worked fine for me, the Sportwagon springs are close, too. Perhaps a tad stiff for street use, I don't have any street GT experience. Physical dimensions of the spring are what to look for first, do they fit in the bucket and top perch? They can be shortened, then the critical factor becomes the spring rate, which is easily checked with simple equipment found at a race car shop. Or just put them in and see if you like them. Ride height is very adjustable! The springs pop in or come out in a matter of minutes, when you get practiced up at it, believe me. If I was doing a street car I'd be looking at air springs that are the rage nowadays.
jeff denton is offline
Old 02-04-2007   #7 (permalink)
booeman's Avatar
booeman is on a distinguished road
coil springs
I'e heard of some place in kent or maybe renton WA. that will make custom coils, I need 4 600LB (so I'm told ) for a stock fit on my 71 sport coupe. I'll find out more in the coming week and keep you posted
booeman is offline
Old 02-04-2007   #8 (permalink)
Viking
hallgeir's Avatar
Real Name: Hallgeir
David
That is a common problem, I`m afraid. Too common, in my opinion.
Hallgeir
Opels now:
Previous Opels:
hallgeir is offline
Old 02-04-2007   #9 (permalink)
Yellow Pages ...
Have a look in your local Yellow Pages under: "Springs & Spring Manufacturers"
There is bound to be an old Blacksmith shop somewhere near that has been re-tempering and making springs since buggy days!
We have three or four in Christchurch, NZ
Old 02-04-2007   #10 (permalink)
Try .........
Coil Spring Specialties -- individually calibrated coil springs for any suspension need.
Paul
Paul is offline
Old 02-05-2007   #11 (permalink)
jtb
jtb's Avatar
I have 4 springs - two about a foot long, and two a bit shorter, from a GT
I'm not using an Opel rear end anymore, so I don't need 'em...
jtb
jtb is offline
Old 02-05-2007   #12 (permalink)
soybean's Avatar
The sportwagon springs jack the rear end up too much and need to be cut as seen in this http://www.opelgt.com/forums/34350-post42.html The rest of the thread is good reading too. Hth, Jarrell
Last edited by soybean; 02-05-2007 at 10:54 AM. Reason: Still trying to figure out Hyperlinks
soybean is offline
Old 02-05-2007   #13 (permalink)
coil springs
Thanks for all the inputs and I'm considering everything, but I would rather have new springs if at all possible. I don't have the facilities for welding and I would like the original ride .. whatever that is, since this is a totally new experience to me. I emailed coil spring specialities .. haven't heard from them yet. Thanks again.
David
Old 02-05-2007   #14 (permalink)
blancojp's Avatar
Provided Answers: 10
I have Fiero front springs in the rear of my GT. They fit quite well and lowers the car little over 1". They do however give you a stiff ride but I had them laying around.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 02-05-2007   #15 (permalink)
flyboytroy99's Avatar
flyboytroy99 is on a distinguished road
JB, what year Fiero springs will fit our GT? A little online research reveiled that the springs changed after 1987.
70GT2NV
flyboytroy99 is offline
Old 02-05-2007   #16 (permalink)
Lindsay
FIERO Coil Springs for GT
EIBACH coil spring application list following years for FIERO:
Make Model Year Range Chassis Engine
Pontiac Fiero 1985 - 1987 GT 2.8L, V6, Gas, MFI, VIN "9"
Pontiac Fiero 1984 - 1987 SE 2.5L, 4 Cylinder, Gas, TBI, VIN "R"
Pontiac Fiero 1985 - 1987 SE 2.8L, V6, Gas, MFI, VIN "9"
Pontiac Fiero 1984 - 1987 Sport 2.5L, 4 Cylinder, Gas, TBI, VIN "R"
Pontiac Fiero 1985 - 1985 Sport 2.8L, V6, Gas, MFI, VIN "9"
Pontiac Fiero 1984 - 1987 2.5L, 4 Cylinder, Gas, TBI, VIN "R"
So ... I would guess that 1984 to 1987 front springs are same, but rear springs would vary for 4-cyl Vs 6-cyl. Post mentioned using front springs from FIERO.
Varible rate coil might be interesting for OPEL GT, if available.
Lindsay is offline
Old 02-05-2007   #17 (permalink)
Lindsay
Fiero Lowering Springs_JC Whitney
JC Whitney - Automotive at SHOP.COM
HIGH-PERFORMANCE LOWERING SPRINGS
Item ZX811872T
Price $83.99
Application 1984-1987 Pontiac Fiero (Front)
HIGH-PERFORMANCE LOWERING SPRINGS Lower front or rear of body Amount of drop varies depending on application Perfect when you want a lowered stance, improved handling, better cornering and a balanced "feel" while maintaining excellent ride
JC Whitney has new lowering springs for FIERO. Probably would lower Fiero by 0.8" if similar to EIBACH. If FIERO front, stock springs lowered GT approx. 1.0", then these might lower GT too much. Looks like they are not varible rate.
www.partsamerica.com does not list stock springs for FIERO.
Lindsay is offline
Old 02-06-2007   #18 (permalink)
specs
Could someone tell me or direct me to the height specs for a '73 GT and where the measurement is made. I know my springs uncompressed are 11 1/2 inches .. maybe my front springs are old and weak also.
David
