Real Name: Wes Thomas
Unanswered: Group Buy On Rear Springs!!
Does anyone on the site have the early spring specs? I need o.d, i.d, free length (unloaded), and total coil. Or just an extra early coil to send to them to measure. There may be enough interest in these springs to do a few batches (5 minimum per run) with different spring rates, heights, etc. So let's see what happens Chime in! Wes |
Trouble Maker
Real Name: Tony Holcomb
Very cool idea. Can you post contact info, just incase someone wants to go out of their own with way different specs?
Personally, I have a 73 GT and am lowering it 2 in.
Coil Springs Specialties?
Coil Spring Specialties -- individually calibrated coil springs for any suspension need.
Just Googled the name for link. If I am incorrect, please correct me. |
GT Rear Springs
http://www.opelgt.com/forums/3a-fron...-manta-gt.html
See Permalink #5 Lindsay GT (rear only) (stock rear is 150 lbs) >160 lb stock height - For extra load capacity >180 lb 1.25" lower - For use with sport front spring or shackles >180 lb 2.5" lower - For use with shackles and sport spring >200 lb 2.5" lower - For racing use with shackles and sport spring, or with fiberglass racing spring and special ball joints. "Bob" |
Opelitis since 1984
Real Name: Charles Goin
I will be giving them a call.. I will need heavy springs for the rear of the electric..
Opelitis since 1984
Thats what I need for my Kadett as I will be rebuilding the front and rear suspension shortly. Hopefully before springfield.
#10 (permalink) | |
BTW, have you thought about a driveshaft-driven alternator that works only while you're in motion? To help trickle-charge the batteries while in use. Common race-car technique. |
coil springs
Could someone tell me or direct me to the height specs for a '73 GT and where the measurement is made. I know my coil springs uncompressed are 11 1/2 inches .. maybe my front springs are old and weak also.
David |
OGTS has (or had) the Lenk lowering progressive springs (variable rate). They are softer than the stock springs in fact. Ride quality improves, handling has more body roll, but if used in conjunction with sway bars it's not that bad.
