Unanswered: Ee ee ee ee!!
#3 (permalink) | |
Opel Addicts
Did you use the teflon grease when you replaced your bushings? If not, that is probably your "squeak". "squeak". Usually you get a little teeny tube of teflon grease with the bushings. If not you can buy a larger tub of the teflon grease from Summit Racing that will probably last you the rest of your life (several years ago the price was about $13). With the big tub you feel like you can be more liberal with the application. We have used liberal amounts of teflon grease on all our front bushings replacements and have no squeaking problems. HTH Vickie
1958 Rekord Olympia Newest Acquisition 1969 Kadett LS Odette Showroom New Original 1969 GT Omi The Grandmother 1970 GT Octavia Streetrod 1971 GT Opie DESTEC car 1972 GT Olessja Under restoration from being rear-ended 1973 GT Oscar Awaiting Restoration 1975 Manta yellowOmaryellow The Bumblebee 1975 Ascona Sport Wagon: Otto Colonel Mustard 2008 Solstice yellowOliver - "Ollie"yellow |
That's about all that is left. Everything else has been greased with teflon.Just a added question if I replaced these spacers can I get thicker ones to lift the back end up a little bit .Say an inch?
a friend of mine added an inch to the hight of his rear springs on a manta , after that it fell over 2 times and died , going up at the back can be bad if you are trying to get a nose down stance , better to look for rallybobs thread on lowering the front if its just a look you want
UFO pel abductee.
Sometimes squeaks that seem suspension related turn out to be something else. Hood rubber stops or hinges, door hinges or seals, bumper mounts,
under hood components like radiator supports, the list goes on. You may need to have someone do a drive-by across a bumpy area while you stand nearby observing. Noises can telegraph through the car and be quite misguiding as to their origin.
#9 (permalink) | |
UngerDog
Jerry |
Just curious, but did you torque all the rear suspension bolts 'to spec', or did you simply crank everything down tight? Torque specs are critical to the suspension movement, which is exaggerated more by the use of polyurethane. Even with substantial teflon grease, over-tightened polyurethane bushings will squeak like crazy. Just a possibility!
Look at the shock rubber bushings too.
Tire tray is out now . Had squeek before any of the Poly went in the back end .Checked top tray all solid there.I'll try spraying everything but as of now all shocks & bushings are new including sway bar.Only thing left is the springs!.I think.What part of the spring setup would be making the noise?
