Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 3 - Suspension and Steering > 3C - Rear Suspension
Old 06-30-2004   #1 (permalink)
soybean's Avatar
Unanswered: Station Wagon Springs
I have a set of Station wagon springs that I was going to put in this weekend. I have a set of thick bottom rubbers(?) as compared to the thinner set that comes standard on the GT.The question is, would you run these in conjuction with the springs, or use the original type? Also in reading Buckys posts, I noticed he cut off 2 turns off his springs. Is this necessary? I never did cut the set I put on my Manta. Thanks, Jarrell
soybean is offline
Old 07-01-2004   #2 (permalink)
springs
Jarrell;
I just used the ones on the GT (rubber pads), as for cutting the springs, put them in uncut first and then set the car back down and step back and get a good look at it first. If it's not to your liking then cut. I did what you're about to do, but, I didn't cut my springs.
Gene
Old 07-01-2004   #3 (permalink)
soybean's Avatar
Thanks, Gene. I'll try it. Slowly working my way forward.After this it's front suspension. Jarrell
soybean is offline
Old 07-01-2004   #4 (permalink)
Riding Low
ravn99's Avatar
ravn99
sping cut
Just if someone reading has never cut springs.......never use a cutting torch,It kills the temper of the metal,,, use a sawsall or the old way-hacksaw- Just a word from one who made the mistake...
"WHAT YEAR IS THAT 280Z?"
"Is it an old prototype corvette?"
"O.K. what the h*ll is it?"
"You want to sell it?"
ravn99 is offline
Old 07-01-2004   #5 (permalink)
OPEL-LESS!!!
greensmurf20's Avatar
greensmurf20
another alternative to cutting springs is to do as ravn warned about. heat put the spring int he car and heat it to weaken it. we did this in my 51 packard i used to have. we put a 327 in it witha 350TH trans, and the front suspension was still topped out until we heated the springs.
currently own
greensmurf20 is offline
Old 07-01-2004   #6 (permalink)
Driver
opelenvy's Avatar
Real Name: George
opelenvy
I used a cut off wheel on my Dremel. I think it took two wheels per spring, but it worked great. Nice clean controlled cut. Then I just painted the new end.
Born to Drive
73 GT
opelenvy is offline
Old 07-01-2004   #7 (permalink)
opeldean's Avatar
flatten top
after taking out 2 full turns of the sportwagon springs(360 degrees X two)
car still sits a little higher in the back in..approx 1/2 inch
go to a bench grinder and flatten the top of the spring as recommened by old hippie in a prior post..to prevent rocking of spring in bucket
not a good idea to drive the gt with a jacked up back..may change geometry
of torque tube,etc..bad for bearings or bushings?
wagon springs are firmer w/o harshness..I like them
opeldean is offline
Old 07-01-2004   #8 (permalink)
Opel Addict Since 73
Sportwagon75's Avatar
Sportwagon75
B & A
Does anyone have before and after photos of their shortened wagon springs??
Scott D.
Sportwagon75 is offline
Old 07-01-2004   #9 (permalink)
opeldean's Avatar
sportwagon is taller and stiffer
even when cut..a shorter sportwagon spring hold s the rear end up more than
a taller uncut gt spring
opeldean is offline
Old 07-01-2004   #10 (permalink)
Are these the Kadett wagon springs, or the 1900 (Ascona SportWagon) springs? I had read a while ago that the Kadett wagon springs were the "spring of choice", so I salvaged a set from donor at the Pick Your Part a while back. Would SportWagon springs fit? Bucky, what were your springs from?
Old 07-01-2004   #11 (permalink)
springs
Keith;
I sold him the springs, and they're from an Ascona Sportwagon.
Old 07-02-2004   #12 (permalink)
soybean's Avatar
Originally Posted by bucky
not a good idea to drive the gt with a jacked up back..may change geometry of torque tube,etc..bad for bearings or bushings?
I noticed while installing the rear end today, I had to jack up the front of the torque tube to be able to get the two bolts that support it, in. I also didn't flatten out the top of the springs. I just read that post tonight. I might pull them back off. I haven't taken it off the stands yet to see if there is a height difference. I hope to put it on the pavement tomorrow. I'll find out then. But I got new bushings, shocks, brake cylinders, turned drums and shoes put on. I don't know what type of Station Wagon these came off of, they had been stored for the last 20 years. Jarrell
soybean is offline
Old 07-03-2004   #13 (permalink)
soybean's Avatar
Update on Station Wagon springs
I put a tire and rim on the rear to check it out. I appears that I am going to have to cut the springs. I did not take it off the stands to let it set on the ground yet. I'm going to wait until I rebuild the front suspension, put it on and then see how she looks. That too, is easier said than done having spent the better part of the afternoon taking the spare apart. Bucky, what size tires and rims do you have on yours? Are they 13" or 15"? Thanks, Jarrell
soybean is offline
