Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 3 - Suspension and Steering > 3C - Rear Suspension
Old 01-11-2006   #1 (permalink)
73Manta72gt's Avatar
73Manta72gt
Unanswered: rear sway bar from Manta on a GT?
Can the rear sway bar from a Manta be used on a GT?
Thanks
73Manta72gt is offline
Old 01-11-2006   #2 (permalink)
Jeff Pozorski's Avatar
Jeff Pozorski
The Manta has a much wider track than the GT which makes the Manta sway bar to wide to swap onto the GT. Keep an eye on Ebay they (the GT sway bars) show up on a regular basis.
Opelerjeff
Jeff Pozorski is offline
Old 01-11-2006   #3 (permalink)
jtb
jtb's Avatar
I've got a rear sway bar from my GT which I will not be using. I was going to put it on ebay once I figured out what it's worth... Any interest?
Thanks,
jtb
jtb is offline
Old 01-11-2006   #4 (permalink)
Thanks,
jtb
I'd be interested, if no one else is.
Old 01-11-2006   #5 (permalink)
Killer Texas GT's Avatar
alternative sway bars
The rear sway-bar from a Impulse(up to 87) or the Buick Opel by Isuzu will work on the GT.You have to weld the mounts to the rear end the rest bolts up at the stock location on the GT. They are the same dia. as the Manta or even the Adco rear sway-bars. The bends are the same for clearances of the GT rear end as they are all made from the OPEL designed housing.
Killer Texas GT is offline
