+ Reply to Thread
Results 1 to 3 of 3
Thread: KONI Shock absorber 80-1997 opel GT
    Hi everybody
    My Opel GT 1900 needed new shock absorber for the rear axle, and I found these "KONI 80-1997 Sport" in a local shop.
    Looking at www.koni.com , it should be the right size for Opel GT rear axle, but it seems that they are too long, and minimum lenght is a lot longer than the old Monroe shocks , which looks very old.
    ( in normal position the shocks are only 5 cm longer , than the minimum lenght they can be )
    Rear springs are the series, and the hight of car is correct .
    Anybody who knows if this will give problems ?
    Gary - and all of You
    Thanks for a very good and useful site, I have been whatching for some time, as a "passive member", - only been GT owner for 2 years now.
    H.N.
    Driving Opel GT 1900 in the summer
    & Opel Astra in the winter
  2. #2
    Member 1000 Post Club Paul is on a distinguished road
    Ft Smith, Arkansas
    1,489
    The longer shock might bottom out before the suspension bottoms. If that happens the shock might be damaged. However, I don't know for sure if these will bottom out. To find out, you can: Place the car on jack stands, remove the rear coil springs and install the koni shocks. Then using a floor jack move the axle thru the full range of travel. If the shocks bottom out before the axle rests on the rubber bump stops then you have a problem
    Since it is a Koni, you can send them to any authorized Koni repair center and have them modified, if you find the extra length a problem. In the US such places are Koni of North America, True Choice and several others. You should be able to find a repair center from their web site.
    Good Luck
    Paul
  3. #3
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,072
    H we have a member selling some konis in the ads section , why not ask him the part numbers for the rear ones
    B.O.O.B. founding member
+ Reply to Thread
