Unanswered: Wheels (again)
Will these fit: 13x7 4x100, 38mm offset approximately 5.5” backspace I would like the tires to be 20.0 x 9.5-13 tire. ----- If they do not fit what is the backspace, or offset or whatever that would be needed for a 13x7 wheel? Thanks for the help, I did try to search, but everyone likes to go with larger wheels I need to stay with 13's. Thanks for your help, this stuff is just a mental block with me. |
#2 (permalink) | |
Here's Travis' GT with my wheels and tires fitted. Bob |
Two Considerations ...
For a GT:
The 'off-set' at ET38 (38mm) needs to be reduced to ET28 (28mm) by use of a 10mm spacer on the front to get the steering geometry into spec. This does depend on the actual diameter of the tyres so you have a range of between 1/2"(12.7)mm and 3/4"(19.1mm) spacer thickness you can use on the front and still be "close enough". A 3/4" spacer would reduce the 'back-space' by that amount 5.5" - 0.75" = 4.75" which should just about clear things on the front. At the rear wheels you can space a bit further because "steering Geometry" is not so involved there - the rear wheels don't turn! So you can use wheel spacers to centre the wheel under the rear guard - once again about 3/4" to get the wheels out far enough to clear the body (the lip along the chassis rail is the thing to keep clear of here). The 'back-space' is the distance the mounting surface is away from the inside edge of the rim. The 'off-set' is the distance the mounting surface is away from the centre of the rim. Larger Positive 'off-set' moves the rim inwards. HTH
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 04-30-2007 at 03:48 PM. |
Yes, it's me, still looking to fill my Stienmetz flares better (especially on the back) Ultimately I'd like some sort of mag rim, (still like the slot mags) and as wide as I can get away with. I guess I'm after the look that Gil and Kyle got, wide and low. Anyway I made this to help me get it straight. Maybe it will help others.
which car, please!
Please, when you ask a question about wheels, specify which model of car you are looking for.
Formulas you need to do your own math: Rim Width / 2 = Centerline Centerline + Offset + Rim Lip = Backspacing 8" wide rims / 2 = 4" Centerline 4" centerline + 0.63" Offset + 0.25" Lip = 4.88" Backspacing
