Old 06-04-2007   #1 (permalink)
jvandyke's Avatar
Unanswered: wider slot mags
These look like the wheels I want. Wider than average slot mags.
from this auction:
http://cgi.ebay.com/ebaymotors/Opel-...17937914QQrdZ1
picture "borrowed" below
Someone buy this and sell me the wheels, thanks.
jvandyke is offline
Old 06-04-2007   #2 (permalink)
Lindsay
GT w/ Optional 8-Track & Limited IMSA Moon Roof!
Complete with option 8-Track Stereo with limited (rare) IMSA Moon Roof. I like the Sellers Rating System: Condition is rated A to G.
Just the ashtray alone could sell for $100 to the right ebay Buyer!
I do like the wheels. They look deeper than mine.
Lindsay is offline
Old 06-04-2007   #3 (permalink)
Dangerous Wheels!
Not enough 'Offset' - they stick out too far!
Old 06-04-2007   #4 (permalink)
UngerDog
ungermm's Avatar
The A70-13 tires themselves aren't that wide, and they're probably mounted on 5.5 inch rims. Those rims look like they are deep dished ones (negative offset) and gives a wider look on the car. There may even be wheel spacers used between the rims and the hubs to further push the wheels out.
ungermm is online now
Old 06-04-2007   #5 (permalink)
Exactly!
Originally Posted by ungermm View Post
... Those rims look like they are deep dished ones (negative offset) and gives a wider look on the car. There may even be wheel spacers used between the rims and the hubs to further push the wheels out.
In Baz' copyright saying: "Spinny, spin - Die! DIE!
God preserve the rest of us roadusers from people who buy critical components because they LOOK good!
Old 06-04-2007   #6 (permalink)
Lindsay
Wheels and Offsets Thread
Excellent discussion regarding wheels and offsets:
http://www.opelgt.com/forums/3d-whee...ferrerid=14028 See permalink #10.
Lindsay is offline
Old 06-04-2007   #7 (permalink)
jvandyke's Avatar
Yes, geometry on fronts "appears" to be approaching dangerous, rears though, that might be okay, anything to fill those Steinmetz flares, (on the rear) Should be able to get better fitting (appropriate) slot mags for the front.
jvandyke is offline
Old 06-04-2007   #8 (permalink)
jvandyke's Avatar
Yep, ideally the rear's I'm after would have as much rim on the inside as the out (well, ideally just what's needed to maintain good offset, 10" rim, 4" inboard, 6" outboard, or whatever)
Yes, I now, racing wheels, shut up and pony up the green Jeff.
I did email these guys, I'm thinking Challenger 14", to see if they're streetable, if so, and rubber is available for somethingn like that, cool, no?
Not exactly slot mags but, well, a possibility and darn cheap too. What's the catch? I think they'd look awesome in chrome, no?
http://www.diamondracingwheels.com/RoadRaceSeries.htm
jvandyke is offline
Old 06-04-2007   #9 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
diamond
Last I had heard Diamond wasn't doing a great job with 4x100mm rims. Seems more than once they sent someone 4x4" and called it 4x100.
But not to worry, if you order from them and it does happen you can send the 4x4" wheels to me to use on my MG.
oldopelguy is offline
Old 06-04-2007   #10 (permalink)
jvandyke's Avatar
Supposedly they have a retailer pretty close to me, maybe I'll go through them, then I got some leverage?
jvandyke is offline
Old 06-04-2007   #11 (permalink)
Three things to consider:
1) These are racing wheels, and are technically not DOT legal. The rim shells tend to be rather thin, so they don't tolerate potholes.
2) Steel racing wheels are often not very concentric. Heck, most mini-stocks bend wheels every racing weekend, so if they're not perfect when new, who cares? However for road use, a small vibration from a wheel that's not true might drive you nuts. Some brands are better than others, I can't comment on the Diamonds because I have not tried them before.
3) You MUST buy racing lugnuts to fit these wheels. OEM wheels use a 60 degree taper on the lug nuts. Steel racing 'stock car' type wheels all use a 45 degree taper. If you do not use the correct taper lug nuts, the wheels will crack at the lug nut holes and fail....
Now that I've sufficiently warned you, happy shopping!
Old 06-04-2007   #12 (permalink)
3) [I]You MUST buy racing lugnuts to fit these wheels.
A fourth thing! Not as important has the three things previously stated but all the racing lug nuts I've seen require a larger lug wrench or socket than the OEM lug nuts.
Old 06-04-2007   #13 (permalink)
jvandyke's Avatar
Thanks, I did manage to figure that stuff out although the big unknown is will they be usable on the street and still safe. I don't really care what the DOT says, like most government institutions, I don't trust their judgement. I ask people who know, like you guys. Anyone use Diamond wheels on the street, or is it just "common sense" not to use such wheels in a street application?
jvandyke is offline
Old 06-06-2007   #14 (permalink)
jvandyke's Avatar
Here we go
http://www.opelgt.com/photos/showphoto.php/photo/10824
jvandyke is offline
Old 06-06-2007   #15 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
I have a set of those slotted mags....the rears only. The only problem I found with them is that I'd need to buy spacers to use them.......not.
yellaopelgt is offline
Old 06-06-2007   #16 (permalink)
jvandyke's Avatar
deep wide ones? I'm sorta hoping I can pick up some like that for rear, something similar looking but geometrically correct for the front. I've always liked those period looking wheels, even before I got the GT I was keeping an eye open for slot mags.
jvandyke is offline
Old 06-06-2007   #17 (permalink)
yea...deep and about 9" edge to edge...... problem is that the lugs arent long enough to get a nut on them when the rim is on. I use them to set the car wheels on when I pull motors!!!! Best security I found to be under the car with! Much better than jackstands.
Joe
Old 06-07-2007   #18 (permalink)
Sparky73's Avatar
Real Name: Jon
Sparky73
jvandyke, sorry I havn't gotten you any more information on that car/wheels. HOPEFULLY if I can get a trailer, I will be picking it up tomarrow (Friday). I will send you a PM with all the information I can provide, as well as uploading some pictures onto the website. I also know your looking for glass, and I know the PARTS car (not the street/strip) has good glass from what I can remember. I will keep you updated for sure. I am going to be parting out the one car FAST because I need money. Already blew a head gasket and a soft plug in the "Turbo GT"
Current
1970 GT; Under Construction
Previous
1969 GT; Street/Strip Project
1969 GT; Black Parts Car
1969 GT; White Parts Car
1972 GT; Red Parts Car
Sparky73 is offline
Old 06-07-2007   #19 (permalink)
Mr corey suggs
sugg578's Avatar
sugg578 is on a distinguished road
They had moon roofs
IT MY WORLD, COREYS WORLD Official EX-PREDIENT of the MWTE! © Mr. Corey Suggs
sugg578 is offline
Old 06-07-2007   #20 (permalink)
jvandyke's Avatar
Joe
I don't quite get the lug nut issue. You can't get a lug wrench/socket on the lug nuts? What's the problem, finger tight is good enough I'm sure.
Must be what Harold was talking about in post 12. Just need different lug nuts or wrench or both? That doesn't seem like a big deal.
At least I'm finding out there's some wheels floating around out there that might work.
jvandyke is offline
Old 06-07-2007   #21 (permalink)
When the rim is on the car,the threads arent long enough to get a lug-nut on........
Joe
Old 06-07-2007   #22 (permalink)
jvandyke's Avatar
Joe
Hmmmmm, stupid question probably but is the hub face that "thick"? I guess I don't understand why different offset would effect this.
jvandyke is offline
Old 06-07-2007   #23 (permalink)
Thats excactly what the problem is......I got these things MANY years ago from a guy that "gave" me a GT. By that I mean that I had free dibs on a whole GT as long as I cut it up for him to get rid of.(nothin finer than drinkin beer and going nuts with a chop saw and a torch!!!!) He said they came on that car when he got it but I have no idea if thats true or not. The bolt pattern is perfect, just that you cant get more than 3-4 spins on the lug-nuts till you run out of thread....like I said before....perfect for jacking up the car and thats about it.
Joe http://www.opelgt.com/forums/3d-whee...ms-anyone.html
Old 06-07-2007   #24 (permalink)
jvandyke's Avatar
Weird. Could put in longer studs I guess or just weld the wheel on the hub, that sounds easier.
jvandyke is offline
Old 06-07-2007   #25 (permalink)
West Coast GT's Avatar
West Coast GT
Here's the opposite situation:
My GT has a set of the slotted alum mags, and I replaced the original Opel tapered lug nuts with new chromed mag lug nuts.
My problem was too much bolt thread, which resulted in using chrome washers. I considered cutting off the extra thread length, but I like the option to use the original rally wheels again.
By the way - the 13" tires that fit the slotted rims were are a bit shorter/wider than the ones on the rally rims. That should give me the option of using the taller/thinner rally wheels/tires to get better milage on trips, but a smoother ride with better looks (my opinion) of the slotted mags around town.
I haven't actually put this to the test since I just got the car registered for road use yesterday and haven't taken it out for the initial drive yet.
West Coast GT is offline
